Magnitude and phase angle of the resistor voltage
The discussion focuses on calculating the magnitude and phase angle of the resistor voltage in an electrical circuit. The correct expression for the magnitude, derived from the impedance, is given as |M| = R / √(R² + ω²L²), where R represents resistance and L represents inductance. The solution confirms that the magnitude can be expressed more elegantly by separating the numerator and denominator. The phase angle can be determined using the arctangent function based on the impedance components.
  • Understanding of complex impedance in AC circuits
  • Familiarity with phasor representation of voltages and currents
  • Knowledge of basic circuit components: resistors and inductors
  • Proficiency in using trigonometric functions for phase calculations
  • Study the concept of complex impedance in AC circuit analysis
  • Learn about phasor diagrams and their applications in circuit analysis
  • Explore the use of the arctangent function for phase angle calculations
  • Investigate the effects of frequency on impedance in RLC circuits
Electrical engineering students, circuit designers, and professionals analyzing AC circuit behavior and impedance characteristics.
Saeed.z
the question is to find the magnitude and phase angle of the resistor voltage in the circuit below :
http://img513.imageshack.us/img513/1035/ee204.jpg
i want you guy's to check my solution please .
thanks .
You've arrived at correct results, although your magnitude could perhaps be expressed a tad more elegantly. If you begin with your expression for M and realize that resistance R is a positive constant, then the magnitude of the numerator and denominator can be taken separately:
##|\hat{M}| = \frac{|R|}{|R + j\omega L |} ##
and then
##|\hat{M}| = \frac{R}{\sqrt{R^2 + \omega^2 L^2}} ##
