Projectile motion baseball problem
The problem involves projectile motion, specifically analyzing the trajectory of a baseball hit from ground level, reaching a maximum height, and clearing a fence at a certain distance. The original poster presents a scenario where the ball's maximum height and the height of the fence need to be determined, along with the distance it travels beyond the fence.
  • The original poster attempts to calculate the maximum height using kinematic equations but struggles with determining the initial angle needed for further calculations. Some participants suggest finding horizontal and vertical velocities first, while others provide their own calculations for the maximum height and fence height, noting the symmetry of the problem.
Participants are exploring different methods to approach the problem, with some providing calculations and others questioning specific values used in those calculations. There is no explicit consensus on the best approach, but several lines of reasoning are being discussed.
The original poster expresses frustration over the lack of an initial angle and the resulting difficulties in solving the problem. There is an emphasis on the symmetry of projectile motion, which some participants reference in their explanations.
missrikku
[SOLVED] projectile motion problem
Hello guys,
This particular problem has been giving me a headache. I can't see how to figure out this problem w/o being given an inital angle. Here it is:
A baseball is hit at ground level. The ball reaches its max height above ground level 3 s after being hit. Then 2.5 s after reaching its max height, the ball barely clears a fence that is 97.5 m from where it was hit. Assume the ground is level. a) What max height above ground level is reached by the ball? b) How high is the fence? c) How far beyond the fence does the ball strike the ground?
Ok, to start out I drew the picture and labeled it and everything. Then..
a)
Y-Yo = Vt - 1/2 at^2
max height = m = 0(3) - 1/2 (-9.8)(3)^2 = 44.1 m
Ok, this is where I get stuck. I'm thinking about using the trajectory equation, to get the height of the fence.
y = (tan@)x - (gx^2)/(2(Vocos@))^2
I'm thinking that y = the height of the fence and x is the distance to the fence. So, x = 97.5 m.
But I don't know how to get the angle, @!
It's been driving me nuts because I tried different ways, but kept getting answers that didn't match.
Here's some of what I tried:
X = Xo + Vt - 1/2 at^2
X = 0 - 1/2 (-9.8)(3)^2 = 44.1m
Then since X = 44.1= Y
I did (44.1^2 + 44.1^2)^(1/2) = 62.4 m
Then sin@ = 44.1/62.4 --> @ = about 45 degrees
Is that correct?
How should I approach the rest of the problem?
Thanks much!
Try to find the horizontal velocity and vertical velocity first before you try anything else.
Then you can use the elapsed time to reach the maximum height and the horizontal velocity to find the total distance travelled.
NOTE: The initial velocity is NOT zero.
Ahhh...haven't done these problems in a while. *Feels nostalgic*
Here's how I did your problem:
a) Max height of ball.
Acceleration due to gravity = -9.81ms-2
Initial vertical velocity = unknown
End vertical velocity = 0
Time taken to reach end velocity = 3s
Using v = u + at,
0 = u + (-9.81)*3
u = 29.43ms-1
Then, using v^2 = u^2 + 2as
s = 44.145m (as you got)
b) Height of fence.
Note: Problem is symmetrical.
Therefore height of ball at t = 0.5s after hit is same as 5.5s after hit.
s = unknown
u = 29.43ms-1
t = 0.5s
a = -9.81ms-2
Using s = ut + 0.5at^2
S = 13.48875m
c) Distance beyond fence.
Note again: Problem is symmetrical.
So distance = 0.5*17.72 = 8.86m
Hello, and sorry for upping an old thread.
Could someone please tell me where the 17.72 is coming from in the above calculation ?
I've spent the past hour trying to figure it out but I couldn't find an answer.
Thank you very much in advance :smile:
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 39 ·
