Reaction of acetone with oxalic ester
  • Thread starter Thread starter maverick280857
    Acetone Reaction
The discussion revolves around the reaction of acetone with oxalic ester in the presence of sodium ethoxide, focusing on the products formed and the underlying mechanism. Participants explore various mechanistic pathways and the nature of the products, including potential cyclic structures.
  • One participant suggests that acetone reacts via its enol form, proposing that the product would be an oxalic acid dienolate formed through a transesterification mechanism.
  • Another participant proposes an addition-elimination reaction where acetone acts as a nucleophile attacking the carbonyl carbon of the ester, potentially leading to a cyclic compound.
  • A later reply indicates that the cyclic product may arise from an intramolecular reaction, although the specifics remain unclear.
  • One participant discusses the role of sodium ethoxide as a strong base that can abstract an acidic alpha hydrogen from acetone, leading to a carbanion that attacks the carbonyl carbon of the ester.
  • Participants express uncertainty about the mechanism for forming the cyclic product and acknowledge the complexity of the reaction.
Participants do not reach a consensus on the exact mechanism or the nature of the products, with multiple competing views and ongoing uncertainty regarding the formation of cyclic structures.
There are unresolved questions regarding the specific mechanism of the reaction, particularly how the cyclic product is formed, and participants reference various texts without arriving at a definitive explanation.
maverick280857
Hello again
What is/are the product(s) when acetone reacts with oxalic ester in presence of sodium ethoxide? I would be grateful if someone could explain mechanistically.
Thanks and cheers
vivek
Chemistry news on Phys.org
Acetone will give the reaction via its enol form, thus, [tex]H_3C-C(OH)=CH_2[/tex] form will be responsible for the reaction. If an ester is reacted with an alcohol in the presence of a base, transesterification (ester exchange) will occur, so the product would be oxalic acid dienolate, I think. The mechanism probably involves the deprotonized acetone (enolate form) to attack the ester's carboxylic carbon, making the previous esteric alcohol be removed as its alcoholate. So the brief reaction should be like this:
[tex]H_3C-C(O^-)=CH_2 + ROOC-COOR \longrightarrow H_3C-C(=CH_2)-(O-OC-CO-O)-C(=CH_2)CH_3 + 2RO^-[/tex]
Perhaps its a addition elimination reaction, with the acetone as the nucleophilic component attacking the carbonyl carbon and under the right conditions...a cyclic compound.
Thanks for your help. According to the answer I have, there are two producs: one of which is cyclic.
I'll try and post the products here but I couldn't figure out how the mechanism works...(to be precise, what the mechanism is).
If you write the products, we will try to devise a mechanism for them.
The addition elimination mechanism can be found through the index of your text.
I know but I couldn't figure out how a cyclic product was formed. Okay well I'll try and look at this again.
Thanks
vivek
It's probably an intramolecular reaction involving the same mechanism.
I had an idea...dunno if its generally okay...
Sodium ethoxide being a relatively strong base can abstract the acidic alpha hydrogen atom from a ketone (since abstraction from an ester would lead to relatively unstable intermediates--in particular one involving crossconjugation) and the carbanion thus formed could attack as a nucleophile on the 'carbonyl carbon of the ester'. The intramolecular attack of the oxygen atom (with a negative charge now) would then force the (otherwise weak leaving group) oxy-substitutent out of the compound thus forming a so called Claisen Schmidt condensation product.
Having said this, I get one answer correct but not the second one. There's still a mystery (I am still looking up all the books I can find) as to how the cyclic product can be formed...and I know that once I figure it out, I am going to have to bang my head into the nearest inelastic wall...
Cheers
vivek
Yeah I've figured out both the products...thanks.
