| New Reply |
v > c for beta-rays? |
Share Thread | Thread Tools |
| May11-12, 02:27 AM | #1 |
Hello, I repeat my question
As is well known that radioactive decay is a random, automatic phenomenon that nothing can stop it. This is unaffected by any variable such as temperature, pressure, acceleration. Each radioactive element has a specific fixed as half-life, wavelength and period, which is fully stable and unaffected. Imagine a spaceship made of depleted uranium in the earth is moving at a speed approaching that of light. B-rays emitted in the direction that moves beyond the speed of light? No, says the special theory. But then is the paradox. A Geiger counter in the spacecraft detects radiation and another mounted on the outside 'in front of the window' was not detected. Both are stationary observers on the craft. To illustrate this, suppose that the craft is made of non-radioactive materials and moving towards earth with a constant speed. Inside there's a piece of uranium, a Geiger counter in front of A is in relation to the direction of craft speed and a second B behind it. If the speed is low, both counters detect radiation. Recall here that the speed of light is constant independent of the observer and inaccessible. So if the speed is equal to that of light, A did not detect radiation. Which of the two would happen if there was no earth or other reference point to know the speed? That is, whether the rings A or not, depends on the observer. The theory introduces a new conception of reality, where a natural phenomenon does not happen by itself, but depends on the existence of observers. But you say, nobody can approach the speed of light. But perhaps one core of radioactive isotope in a large accelerator can do. You just have to try it, if there at CERN read our articles. We will see then if the speed prevents the decay of the nucleus, which is, as we said, a random phenomenon. And how the core 'knows' that moving relatively to the observer to 'postpone' its breakdown of? |
| May11-12, 03:25 AM | #2 |
Recognitions:
The postulates of relativity:
1) principle of relativity means that there is no preferred state of motion, which directly means that the outcome of your rocket experiment is independent of its velocity. 2) speed of ligth the same in every reference frame means that there is no reference frame where the speed of light is zero as in your "So if the speed is equal to that of light, A did not detect radiation.". Which means again that the rocket can't go at the speed of light. So, even without any math, your conclusions directly contradict the postulates that the theory is built on. You sure you're talking about relativity? Where did you learn it from? As to your questions, |
| May11-12, 04:09 AM | #3 |
I am not talking about time dilation,what I am asking for is that if the moving core decays,b-rays emmited beyond the speed of light?
| May11-12, 04:28 AM | #4 |
Recognitions:
You mean, kind of v(beta relative to earth) = v(rocket) + v(beta relative to rocket) > c?
Try this: http://en.wikipedia.org/wiki/Velocity-addition_formula |
| May11-12, 06:19 AM | #5 |
Thank you,I'll see it,but what about the isotope core emission relative to lab?
| May11-12, 06:25 AM | #6 |
Recognitions:
| May11-12, 07:38 AM | #7 |
[tex]\frac{.9c+ .9c}{1+ \frac{(.9c)(.9c)}{c^2}}= \frac{1.8c}{1.81}= .99c[/tex] still less than the speed of light. |
| May11-12, 10:40 AM | #8 |
Mentor
If you believe otherwise then please provide a mainstream scientific reference which states that. |
| May11-12, 10:53 AM | #9 |
| May11-12, 11:34 AM | #10 |
Thank you all
What I ask in my first question is that if A counter rings,is this for an observator on earth means that b-rays beyond the speed of light? |
| May11-12, 11:36 AM | #11 |
Again, no, the formula isn't [itex]\vec{v}_{1,3}=\vec{v}_{1,2}+\vec{v}_{2,3}[/itex].
| May11-12, 11:38 AM | #12 |
Mentor
Also, a Geiger counter does not measure speed of a radioactive particle, it only detects its presence. To measure speed you will need something else, like a Doppler radar.
| May11-12, 11:55 AM | #13 |
| May12-12, 11:06 AM | #14 |
Ok,but what about γ-rays also emitting by the nucleus?
| May12-12, 11:10 AM | #15 |
Remember that if we use the relativistic formula for adding speeds, if something's moving at c in one reference frame, it's moving at c in all reference frames (in fact, ignore the relativistic formula for adding speeds, this is what Special Relativity comes from), and if something's moving at <c in one reference frame, you get a speed of <c in all reference frames. |
| May12-12, 11:41 AM | #16 |
If you placed your apparatus ( the emitter and the detectors ) in any non-accelerating lab it will give the same results. The laws of physics are the same in all inertial frames. You should be aware that there is no absolute motion. The lab may be moving close to c with respect to some other frame but that is irrelevant. In the lab frame there are no relativistic effects. If the emitter was in motion with respect to the detectors, there would relativistic effects like time dilation, but the counts of the detectors would be the same in all frames, although the rate of detection might be different. |
| May12-12, 12:14 PM | #17 |
Forgive me but I have doubts until this could be experimentally assured.I asked for it:
"But perhaps one core of radioactive isotope in a large accelerator can do. You just have to try it, if there at CERN read our articles." The core is moving close to c and emitts γ-rays.The frame is the lab. Supposed that math produce physics you know Zenon's parodox. |
| New Reply |
| Thread Tools | |
Similar Threads for: v > c for beta-rays?
| Alpha and Beta rays | High Energy, Nuclear, Particle Physics | 6 | ||
| Why are beta particles less penetrating than x-rays? | Introductory Physics Homework | 3 | ||
| Protection from both beta particles & Gamma rays? | High Energy, Nuclear, Particle Physics | 4 | ||
| Alpha, Beta and Gamma Rays | High Energy, Nuclear, Particle Physics | 1 | ||
| beta rays | General Physics | 1 | ||
