Voltage in Circuits: Why Does Potential Difference Appear?
  • Thread starter Thread starter tonyjk
    Circuit Voltage
The discussion revolves around the concept of potential difference in electrical circuits, specifically focusing on why a potential difference appears across a resistor when a voltage source is connected. Participants explore the relationship between voltage, electric fields, and charge flow in circuits.
  • One participant asks why a potential difference appears across a resistor when a voltage source is connected, noting that a voltage source creates a difference in charges and an electric field that causes electron flow.
  • Another participant references a video that suggests the potential difference over a resistance creates the flow of charges, indicating a connection between potential difference and electric field.
  • A participant cites a book stating that the work done per unit charge in moving a charge in an electric field defines potential difference, questioning who creates the electric field and performs the work.
  • One participant explains that the battery causes its voltage to appear across the points where its wires are connected, and describes voltage in terms of work done per unit charge.
  • A participant seeks clarification on whether the potential difference over a resistance is also the work done by the electric field and questions the nature of charge differences across the resistance.
Participants express varying levels of understanding and seek clarification on the concepts, indicating that multiple views and questions remain unresolved regarding the nature of potential difference and electric fields in circuits.
Participants reference different sources, including videos and textbooks, which may present varying definitions and explanations of potential difference and electric fields. There is uncertainty regarding the roles of electric fields and charge differences in creating potential differences across resistors.
This discussion may be useful for individuals interested in understanding the fundamentals of electrical circuits, particularly those exploring the concepts of voltage, electric fields, and resistance.
tonyjk
Hello this is my first post here :)
Please i would like to know why when we put a Voltage source in a circuit why for exemple a potencial difference appears on a resistance( I know a Voltage source has difference in potential created by difference in charges and an electrical field appears in the circuit so the electrons will flow) but why there's a potentiel difference over a resistance in a circuit and i saw on youtube that the potential difference over a resistance create the flow of charges? how come ? Thank you
PS: i can't post the youtube link since i didnt reach 10 posts yet:P anyways if anyone is interested the title is Resistance and its uploaded by april 1515... and i read several books they say the difference of potentiel creates electric field so the difference in potentiel over a resistance creates a field?
Here's a link to the video:
Resistance
Hope that helps!
exactly thanks:)
plus if you read the book of Field Theory vy A.V. Bakshi it says : "Thus work done per unit charge in moving unit charge from B to A in the Field E is called potential difference between the point B and A" so who creates the field E and who does the work?
Hi tonyjk! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
The battery causes its voltage to appear across whatever points the battery wires are connected to. If the wires are not connected anywhere, then they are actually connected across some air, so the battery's voltage appears across a volume of air. :smile:
The volt is just another name for 1 Joule/coulomb; the Joule being a unit of work. So a 1V voltage source has performed one Joule of work once it has moved 1 coulomb of charge from one terminal of the voltage source to the other terminal. So if you wish to show that you know what you are talking about, you could refer to a 1.5V battery as a 1.5 Joule/coulomb cell. :wink:
okay i understand now more but the potential difference over a resistance is the same? it's also the work done by the electric field? and the difference of potential is it due to a difference of charges?( positive and negative?) so across the resistance there's difference of charges or what? thanks
  • · Replies 18 ·
9K
