New Reply
Heisenberg Uncertainty Principle - find minimum uncertainty in position
Share Thread Thread Tools
May16-12, 06:41 PM   #1
Assume speed of 435g football is known with 1mm/s uncertainty.
What is the minimum uncertainty in its position?
2. Relevant equations
I'm not quite sure... I know p=mv, and I know that Heisenberg's uncertainty principle states that certain parameters of quantum particles cannot be measured/known at the same time without uncertainty.
When I did a previous example, I used the formula:
dx ≥ h/(4∏mdu)
where dx = uncertainty in position
h = plancks constant
m = mass in kg
du = uncertainty in velocity
3. The attempt at a solution
Well I was trying to do it using the formula given above, but there are a couple of things I don't understand.
i) How do I find du?
I previously found du by multiplying the speed (given in question) by the uncertainty, which was in percentage form.
How do I find du now? I'm not actually GIVEN a speed, and I don't quite know what to make of "1mm/s uncertainty." Is that 0.001%, which would be 0.00001, or...?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
May16-12, 06:49 PM   #2
Quote by daleklama View Post
dx ≥ h/(4∏mdu)
m = mass in kg
The uncertainty appearing in the uncertainty principle is always a quantity with units of position or speed, not a dimensionless ratio (or percentage) of quantities. In this case, the uncertainty in the velocity is given to you directly in the problem. The actual velocity is irrelevant for the application of the uncertainty principle, in cases where you know the uncertainty directly. The actual velocity is only relevant when you use it to infer what the uncertainty in the velocity must be (e.g. if you are a given a problem that says "the velocity of the football is measured to be 10.000 m/s -- in which case you are being indirectly told the uncertainty in that measurement).
May16-12, 07:20 PM   #3
Okay, I'm not sure if I'm doing this right, but in that case, would the following be a correct calculation?
dx ≥ h/(4∏mdu)
m = mass in kg
dx ≥ (6.626e-34)/(4∏(0.435)(0.001)
dx ≥ 1.21e-31 m
I used 0.001 as the uncertainty because it's given as 1 mm/s, and I felt I should convert that to metres?
Thanks very much for reply :)
May16-12, 08:15 PM   #4
Yes, this is fine. Certainly you do want to have the velocity uncertainty in SI units if your other units will be too.
May17-12, 02:55 AM   #5
Thank you :)
New Reply
Thread Tools
Similar Threads for: Heisenberg Uncertainty Principle - find minimum uncertainty in position
Thread Forum Replies
Heisenberg's uncertainty principle, find uncertainty in position Biology, Chemistry & Other Homework 1
Heisenberg's Momentum-Position Uncertainty Principle Advanced Physics Homework 10
uncertainty principle, relating the uncertainty in position to the uncertainty Advanced Physics Homework 3
find minimum energy of a particle using the uncertainty principle... should be easy? Advanced Physics Homework 1
