New Reply
Help with electrostatics : Charging and reconnecting a capacitor .
Share Thread Thread Tools
May17-12, 02:57 AM   #1
So I came by this question yesterday which was in Solved examples part of my Textbook . I looked at the Solution and was not able to figure out how ?
The Question says .
A 5uF capacitor is first charged by applying a Potential Difference of 24 V . a different Capacitor of Capacitance 6uF is charged by applying a Potential Difference of 12 V . These capacitors are now connected such that the Positive plate of the first capacitor is connected to the Negative Plate of Second Capacitor and vice versa(does this mean they are connected in series or is there a different name for such configuration?) . Find the new Potential Difference and the New charge on the capacitors .
2. Relevant equations
The only formula used would be Q = CV
3. The attempt at a solution
The solution had this C1 = 5uF V1 = 24uF therefore = Q1 = 120uC
C2 = 6uF V1 = 12uF therefore = Q2 = 72uC
Then they found out what is called effective potential (thats what confusing me ) . They used this equation
V{effective}(C1+C2) = V1C1 - V2C2
V{eff} = 4.36 V
then they Calculated the V{effective} and the new charges . what I am not able to understand is how did they came by this formula ??
Also when the configuration is like Positive plate is connected to positive and negative to negative(does this mean they are connected in parallelor is there a different name for such configuration?) the effective Potential difference comes out to be 17.45 V . How ? Please explain I just cant get it .
Thanks in advance
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
May17-12, 03:29 AM   #2
The +ve to -ve connection means that two anr now connected in series(That is what basic circuitry says)
Let us now analyse the question:
( E means x10 to power)
5uF charged at Pd of 24v
6uF charged at Pd of 12V
The charge stored in the 5uF capacitor = Q1= CV=5E-6 Fx24=1.2E-4C
" " " " " 6uF " =Q2 =CV= 6E-6 x 12= 7.2E-5C
Total charge(Qe)= Q1 +Q2=1.92E-4C ----New Charge
The total Capacitance (Ce)= (C1xC2)/(C1 + C2)= 2 8/11 uF
New PD= Qe/Ce = 70.4019V
Do you now get it friend?
May17-12, 03:50 AM   #3
Quote by brianonyango View Post
But the Pd across them is not 70.4019 its 4.36 V
http://www.evernote.com/shard/s92/sh...8b2bd326062c42
you can see that here
May17-12, 04:18 AM   #4
Oh I am just checking the solution you gave up there. The V effective is the resulting PD across the two Capacitors.
I tend to think that when connected in series, the charge in any two Capacitors tend to oppose one another so that is why they are being subtracted. Oh this is confusing even me now...
May17-12, 05:08 AM   #5
Let me know if you find a way I asked the same question here http://answers.yahoo.com/question/in...7005924AA8hD5h
and got the reply which somewhat clarifies the thing , can you please elaborate the answer further ?
May17-12, 09:58 AM   #6
Recognitions:
Homework Helper Homework Help
I don't know about this effective potential, so if you must understand your solution manual, then I cannot help you.
I would do it this way:
calculate the initial charges on each capacitor from your basic equation Q=CV (as you did)
calculate the equilibrium charge after connection Qeq=|Q1-Q2| (they are subtracted because the negative from one plate partially cancels he positive from the other plate, and vice versa)
calculate the equivalent capacitance of the combination (which would be effectively parallel as far as the resulting voltage is concerned) Ceq=C1+C2
determine the resulting voltage for the resulting combination from your basic equation Qeq=CeqVeq
New Reply
Tags
capacitor, charges, difference, electrostatics, potential
Thread Tools
Similar Threads for: Help with electrostatics : Charging and reconnecting a capacitor .
Thread Forum Replies
Super Capacitor Banks, Instant Charging, Inversion, Charging Battery Banks, Capacitor Electrical Engineering 6
What really happens when charging a capacitor?? General Physics 2
Capacitor charging General Physics 10
capacitor charging loss (Not the two capacitor issue.) Electrical Engineering 46
Charging a capacitor Classical Physics 10
