What's the difference between entrainment and resonance?
  • Context: High School
  • Thread starter Thread starter quantum1234
    Difference Resonance
The discussion revolves around the concepts of entrainment and resonance in the context of physics. Participants explore the definitions and distinctions between these terms, as well as their applications in understanding vibrations and oscillations.
  • Some participants propose that entrainment occurs when one vibrating object begins to resonate at the same rate as a more powerful vibrating object, while resonance is described as one object causing another to vibrate if they share the same resonant frequency.
  • One participant suggests that entrainment may be viewed as mutual resonance, where both objects influence each other, whereas resonance is typically a one-way interaction.
  • There is a question regarding the interchangeability of the terms 'oscillating' and 'vibrating', with some suggesting that they can be used interchangeably, but noting that "oscillation" might refer to more regular vibrations.
  • A participant expresses confusion about resonance, questioning how an object can be set into motion if everything is already vibrating and how two objects can vibrate at different frequencies while sharing the same natural frequency.
  • Another participant points out that most vibrations in the universe are random, which may contribute to the confusion regarding the concept of natural frequency.
Participants do not reach a consensus on the definitions and distinctions between entrainment and resonance, as well as the relationship between natural frequency and the state of vibration. Multiple competing views and uncertainties remain in the discussion.
There are limitations in the discussion regarding the definitions of terms and the assumptions about the nature of vibrations and frequencies, which are not fully resolved.
quantum1234
This has been confusing me for a couple of days, maybe it's because I just started self teaching physics (which isn't going so well lol)
So entrainment is when one vibrating object begins resonating to the same rate as the more powerful, higher vibrating object. Resonance is when one vibrating object causes another vibrating object with the same resonant frequency, to vibrate.
Isn't is basically the same thing? or are the terms used interchangeably?
Oh and as an added question (i'm sorry) are the terms 'oscillating' and 'vibrating' used interchangeably?
welcome to pf!
hi quantum1234! welcome to pf! :smile:
i think entrainment is mutual resonance … each of two objects affects the other … while resonance is usually one-way
more or less
but i think in practice "oscillation" would only be used to describe a pretty regular vibration (like simple harmonic motion)
Thank you, it makes better sense now, but I am still a little bit confused about resonance.
So resonance causes an object to transfer energy to another object if they both share the same natural frequency AND if the two objects are vibrating at different frequencies.
So what I don't understand is:
"Natural frequency is the frequency at which a system naturally vibrates once it has been set into motion."
- I read a while back that everything in the universe is in a constant state of vibration so how is something set into motion if it's supposed to be already vibrating? And so how can two objects be vibrating at different frequencies if they share the same natural frequency already?
I hope you understand my question, I have a feeling that I worded it oddly, if so please tell me and I'll rewrite it :)
Again, thank you!
(where did you read that? :confused:)
most of the vibrations are pretty random
  • · Replies 18 ·
  • · Replies 18 ·
