Direction of the magnetic force
The problem involves determining the direction of the magnetic force based on the flow of current and the application of the right-hand rule. The original poster expresses confusion regarding the expected answer compared to their own interpretation.
  • The original poster attempts to apply the third left-hand rule but questions the outcome when using the right-hand rule instead. Participants discuss the correct application of the right-hand rule for current versus electrons and express confusion about the expected answer.
Participants are actively engaging with the problem, questioning the application of the right-hand rule, and exploring different interpretations of the magnetic force direction. Some guidance has been offered regarding the distinction between current and electron flow, but consensus on the correct answer has not been reached.
There is mention of an answer key that contradicts the original poster's interpretation, which adds to the confusion. The discussion includes references to specific points and directions that may require visual aids for clarity.
Nitrate
The problem is in the attached image.
I used the third left hand rule (seen in one of the attached images) and pointed my thumb (direction of the current) downwards because the question states that the current flows from point E to point F. However, when I point my thumb downwards I seem to get B as the answer... and my answer key says that A is the answer. I need a bit of clarification please (a drawing might be helpful.)
Hi Nitrate! :smile:
Nitrate said:
I used the third left hand rule …
No, for current, it's the right-hand rule. :wink:
(It's only the left-hand rule for electrons, because the current is defined as going the opposite way to the electrons)
tiny-tim said:
Hi Nitrate! :smile:
My mistake. That being said, I still don't understand why A is the answer.
Hi Nitrate! :smile:
Nitrate said:
… when I point my thumb downwards I seem to get B as the answer …
Nitrate said:
… I still don't understand why A is the answer.
I don't get it :confused:
if your right thumb is down, and your fingers are pointing along the field (from N to S, ie from C to D),
then isn't your palm is pointing towards you, ie towards A ?​
  • · Replies 40 ·
