How Does Gauss' Law Apply to Gravitational Fields?
The discussion revolves around applying Gauss' Law to gravitational fields, specifically in the context of calculating gravitational acceleration at a certain distance from a planet's center. The original poster attempts to derive the gravitational field using the analogy with electric fields and Gauss' Law.
  • Participants explore the derivation of gravitational acceleration using Gauss' Law, questioning the assumptions about mass distribution within a sphere. Some participants raise concerns about the calculation of mass at a distance of R/2 and whether the mass should be considered as halved.
The discussion is active, with participants providing hints and questioning assumptions. There is a mix of attempts to clarify the relationship between volume, mass, and gravitational acceleration, with some participants confirming the correctness of calculations and interpretations.
Assumptions about uniform density and the implications of negative gravitational acceleration are discussed. The original poster's calculations are scrutinized, and the impact of volume on mass is explored.
arl146
The gravitational field g due to a point mass M may be obtained by analogy with the electric field by writing an expression for the gravitational force on a test mass, and dividing by the magnitude of the test mass, m. Show that Gauss' law for the gravitational field reads:
[itex]\Phi[/itex] = [itex]\oint g\bullet dA[/itex] = -4*pi*G*M
Use this result to calculate the gravitational acceleration g at a distance of R/2 from the center of a planet of radius R = 8.05 × 10^6 m and M = 8.45 × 10^24 kg.
above equation
i can't get the answer right for this .. here's what i did
g[itex]\oint dA[/itex] = -4*pi*GM
g[4*pi*r^2] = -4*pi*GM
g[4*pi*(R/2)^2] = -4*pi*GM
g*pi*R^2 = -4*pi*GM
g = (-4GM)/R^2
and since r=R/2 the mass is halved also. therefore g = (-2*G*M)/R^2
i plugged in the values for G, M, and R .. and got -17.40267737 m/s^2 but its not right
anybody can give any hints of what I am doing wrong?
Are you sure about that? :wink:
(What percentage of the sphere's volume--and thus mass, assuming uniform density--is located at r < R/2?)
ummm .. is the mass 1/8 of M? since V= (4/3)*pi*r^3
and since R=r/2 ... that makes it V = (4/3)*pi*(R^3/8)
meaning the volume is 1/8 of the total. and since D = M/V ---> M=DV so the mass also is 1/8 of the original?
Assuming that the density of the planet is uniform, yes, that's correct.
is g supposed to be negative? also i got 4.3506693 m/s^2 is that right can someone check for me?
That looks good. g is negative just means that the field points toward the center.
ok i got it that makes sense. thanks!
  • · Replies 20 ·
  • · Replies 23 ·
