| New Reply |
Rectangular coil rotating in magnetic field |
Share Thread | Thread Tools |
| May23-12, 08:15 PM | #1 |
A rectangular coil of 80 turns has an area of 0.01m^2. It rotates @ 3000rpm about one of its in plane axes, in a uniform magnetic field having B=1.5T. Calculate the rms voltage generated. 2. Relevant equations 1 Tesla= 1 Weber/m^2. Change in flux of 1 Weber per second = 1 Volt induced. 3. The attempt at a solution (80*0.01*3000*1.5)/60 = change in flux of 60 Wb/s. ==> 60V. 60/[2sqrt(2)]=15sqrt(2)Vrms. This is not the right answer. The answer is 267Vrms. |
| May23-12, 08:32 PM | #2 |
Recognitions:
3000 rpm, you need to convert that to rad/s. You didn't multiply by π.
| May24-12, 07:36 AM | #3 |
| May24-12, 11:03 AM | #4 |
Recognitions:
In the formula E(max)=NBAw, B,A and w need to be in SI units (or at least derived SI units) for the units to produce the Volt on the left hand side.
So rpm would need to be converted to radians per second. |
| May24-12, 01:49 PM | #5 |
| New Reply |
| Tags |
| gauss law, magnetic field, rectangular coil, rms |
| Thread Tools | |
Similar Threads for: Rectangular coil rotating in magnetic field
| Angular speed of rotating coil in the Earth's magnetic field | Introductory Physics Homework | 0 | ||
| magnetic field of a rectangular coil... | Classical Physics | 3 | ||
| Rotating square coil in constant magnetic field | Introductory Physics Homework | 2 | ||
| A rotating coil measuring the magnetic field | Advanced Physics Homework | 1 | ||
| A coil with turns given magnetic field, time find the emf induced in the coil | Introductory Physics Homework | 4 | ||
