New Reply
Nodal analysis problem
Share Thread Thread Tools
May24-12, 06:22 AM   #1
I need to solve this circuit using nodal analysis (find the voltage in all nodes), but i need the actual equations used to solve it.
All supplied information is there.
What I've done is to create 2 supernodes, like this
And write the following equations for the three nodes that i have left.
[itex]\frac{V1}{2k}+\frac{V1-V2+6}{2k}= 9mA[/itex]
[itex]\frac{V2}{1k}+ 9mA +\frac{V2+6-V1}{2k}+\frac{V2+6-V3}{1k}= 2mA [/itex]
[itex]\frac{V3-V2+6}{1k}+\frac{V3}{1k}+\frac{V3+89}{1k}+2mA = 0[/itex]
When i try to solve these equations i get V1 = -5.8V, V2=-23V, V3=-40V
I tried to draw the circuit in LTSpice, and the result should be V1=2V, V2=-20V, V3=-35V
What did i do wrong? I've been trying to redo the circuit several times for more than 1½ hour now, but don't get the right answer.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
May24-12, 07:23 AM   #2
Recognitions:
Homework Helper Homework Help
It's a good idea to get into the habit of putting parentheses around the terms corresponding to supernode sub-nodes. That way mathematical operation ordering is maintained when you write your expressions. In your first node equation, for example, note that V1 - V2 + 6 is not the same as V1 - (V2 + 6)
May24-12, 08:12 AM   #3
Quote by gneill View Post
oh god... i can't believe i spend so much time on this.... .. thanks, that solved it :)
New Reply
Thread Tools
Similar Threads for: Nodal analysis problem
Thread Forum Replies
Nodal Analysis/Superposition Problem Engineering, Comp Sci, & Technology Homework 2
Nodal Analysis Problem, Circuits Introductory Physics Homework 0
Nodal Analysis Problem (Basic Circuit Analysis) Engineering, Comp Sci, & Technology Homework 2
KCL/Nodal Analysis Problem Introductory Physics Homework 6
