Increase in voltage = decrease in current?
Increasing voltage in electrical transmission reduces current, which in turn minimizes power losses due to resistance in the lines. This relationship is explained by the equations P=VI and P=I²R, where higher voltage allows for lower current while maintaining the same power output. A numerical example illustrates that at 1000V, power loss is negligible, while at 100V, losses increase significantly. The use of transformers enables the stepping up of voltage for transmission and stepping down for safe use. Therefore, high voltage is essential for efficient long-distance power transmission.
chwl3
Increase in voltage = decrease in current??
Electric power is transferred over large distances at very high voltages. Explain how the high voltage reduces power losses in the transmission lines.
V = IR
P = VI
From searching on the web, many people say increase in voltage will naturally lead to decrease in current, thus reducing the power losses in the lines. With those equations, I cannot understand why a rise in voltage would lead to a drop in current, and not rise? Also, how does drop in current reduce the power loss?
Should add another equation.
p=I2R
The line with resistance will consume power too. If less current means less power loses due to line resistance.
P=IV
With same power usage, either we increase current and decrease voltage(means more power consume by the lines) or more voltage less current.
With these equations you can show the ida with a numerical example:
Suppose you need to supple 2kW of electrical power along cables having a total resistance of 1 ohm.
If the supply voltage is 1000V then the current needs to be 2A and the power wasted in the cables is I^2.r = 4 x 1 = 4Watts...negligible!
If the supply voltage is 100V then the current needs to be 20A and the power loss = 400W...a 10 times lower voltage means 100 times greater power loss.
The principle is to use the greatest possible voltage for transmission but for safety and convenience reasons the voltage at the generator and the user should be low.
This means some way of 'stepping up' voltage for transmission and then 'stepping down' voltage for use is needed. This stepping up and stepping down is easilydone with transformers and this is why electricity is generated as AC...so that transformers can be used.
how about ''P=V^2/R
more voltage means more power dissipation in transmission
asitiaf said:
how about ''P=V^2/R
No because you don't drop your entire voltage over the transmission line.
chwl3 - transmission lines are used to transmit power from one area to another.
Power transmitted = Voltage * Current...(1)
So you can choose any combination of voltage and current that meets the above equation.
The losses in the cable are
Power Loss = current2 * resistance ....(2)
So there is an incentive to use a low current and high voltage in (1).
I think that
P=VI; so, for constant power voltage and current are inversely proportional.
P=I^2R; it is the power dissipated (loss)
during transmission. So, lesser the current, lesser the dissipation and more power delivered.
P=V^2/R; it is the power delivered (carried) during transmission. So, more the voltage, more the power delivered.
Please confirm, whether I am right.
  • · Replies 30 ·
