Find out where this power series converges
The discussion focuses on determining the convergence of the power series Ʃ(xn2n) / (3n + n3) using the ratio test. The user applies the ratio test and derives the limit expression pn = 2x (3n + n3)/[(3)(3)n+n3(1+1/n)3]. They conclude that since 3^n grows faster than n^3, the limit approaches |x| < 3/2. The user expresses uncertainty about the behavior at the boundaries and suggests employing l'Hôpital's rule for further analysis.
  • Understanding of power series and convergence criteria
  • Familiarity with the ratio test for series convergence
  • Knowledge of l'Hôpital's rule for limit evaluation
  • Basic algebraic manipulation skills for simplifying expressions
  • Study the application of the ratio test in depth
  • Learn about boundary behavior in power series convergence
  • Explore l'Hôpital's rule with practical examples
  • Investigate other convergence tests such as the root test
Mathematics students, educators, and anyone studying series convergence in calculus or advanced mathematics courses.
tamtam402
Find out where this power series converges.
Ʃ(xn2n) / (3n + n3)
I'm trying to use the ratio test to solve it. I end up with the following equation, which I am unable to reduce further:
My guess is, since [itex]3^n[/itex] goes to infinity faster than [itex]n^3[/itex] (exponentials are faster than polynomials), is that your ratios go to [itex]\frac{2}{3}x[/itex]. Tnen you want [itex]|x|<\frac{3}{2}[/itex]. Not sure what happens at the boundaries. To check the limit I guessed at, maybe use l'Hopital's rule 3 times?
  • · Replies 22 ·
