| New Reply |
Radioactivity & Specific Heat Capacity Question |
Share Thread | Thread Tools |
| May28-12, 01:35 PM | #1 |
0.2g of a radium salt was separated from a ton of uranium ore. The radioactive radium nuclide Ra-226 decays by alpha-particle emission with a half-life of 1600 years. 1 year = 3.16x107s. The curie is defined as the number of disintegrations per second from 1.0g of Ra. Show that: a)i) the decay constant of the radium nuclide is 1.4x10-11 s-1 ii) 1 curie equals 3.7x1010Bq b) Show that the energy release in the decay of a single nucleus of Ra-226 by alpha-particle emission is 7.9x10-13J. nuclear mass of Ra-226 = 226.0254u nuclear mass of Rn-222 = 222.0175 nuclear mass of He = 4.0026u c)Estimate the time it would take a freshly made sample of radium of mass 0.2g to increase in temperature by 1oC. Assume that 80% of the energy of the alpha particles is absorbed within the sample so that this is the energy which is heating the sample. Take the specific heat capacity of radium to equal 110Jkg-1K-1. Use the data from a) and b) 2. Relevant equations For a)i) I used λt1/2 = 0.693 For ii) I used A = λN (I used Avogadro's constant to find N of 1.0g of Ra-226.) For b) I used E = Δmc2; 1u = 1.661x10-27kg For c) E=mcΔT 3. The attempt at a solution Both part a) and b) were fine, but I'm having trouble with part c) I was thinking of using E = mcΔT and having E = 0.8 x 7.9x10-13, m = 2x10-4kg, c=110; what value of ΔT should I be using? I thought it should be 1 because the temperature is being increased by 1oC? However, that doesn't fit the equation. Also, how can I find the time from this? Should I equate E to Qt or should I be using a different equation? Sorry this is so long; I included parts a) and b) as they might be needed to work out part c). Any help would really be appreciated. Thanks
| May29-12, 12:58 PM | #2 |
find no. of nucleus decayed in time t.
the energy release in the decay of a single nucleus of Ra-226 by alpha-particle emission is 7.9x10-13J. use this to calculate energy released in time t. then, E=mcΔT. |
| May30-12, 07:25 AM | #3 |
I worked out, using Avogadro's constant, that 0.2g of radium-226 has 5.3x1020 nuclei. The question says that 80% of the energy of the alpha-particles heats the sample; so 0.8 x 7.9x10-13 = 6.3x10-13J. So I thought that to find the amount of energy required to heat 0.2g of radium, I'd have to multiply it by the number of nuclei in 0.2g of radium. I tried incorporating this into E=mcΔT, but I'm still not sure how to figure out the time from this ![]() Thanks again
| Jun4-12, 05:28 PM | #4 |
Could anyone help with the above question? My exam is in less than a week...
Thanks :) |
| New Reply |
| Thread Tools | |
Similar Threads for: Radioactivity & Specific Heat Capacity Question
| Specific Heat Capacity question - Help needed. | Introductory Physics Homework | 4 | ||
| Specific heat capacity question | Introductory Physics Homework | 9 | ||
| Specific Heat Capacity Question | Introductory Physics Homework | 0 | ||
| Specific Heat Capacity Question | Introductory Physics Homework | 3 | ||
| Specific Heat Capacity question | Introductory Physics Homework | 3 | ||
