Using ventura setup to induce oxygen into water.
  • Thread starter Thread starter Robin07
    Oxygen Water
This discussion centers on using a Venturi setup to induce oxygen into a pond's water to reduce algae growth. The user proposes creating a hole in the in-fill line that feeds circulated water from the reservoir, using an inverted funnel to prevent dirt entry. The goal is to allow air to be sucked into the water line before it reaches the falls, enhancing oxygenation. The user questions whether a one-way valve is necessary or if the water flow will naturally draw in air.
  • Understanding of Venturi effect principles
  • Knowledge of pond aeration techniques
  • Familiarity with plumbing and water circulation systems
  • Basic skills in DIY projects involving PVC materials
  • Research "Venturi effect applications in aquaculture"
  • Learn about "DIY pond aeration systems"
  • Explore "one-way valve installation in water systems"
  • Investigate "algae control methods in ponds"
Pond owners, aquaculture enthusiasts, DIY hobbyists, and anyone interested in improving water quality and reducing algae in aquatic environments.
Robin07
I would like to use a ventura type of setup to induce/atomize oxygen into water.
I have a pond that gets clearer as I spread out the same amount of water falling into the pond. The more I spread the falling water out causing multiple areas that crash down on the rock or the surface water, the clearer the water get over time. I've reached a point that I'm not able to spread the water out anymore, without sacrificing esthetics.
I would surmise that the more oxygenated the water is the less algea in the pond. So, I propose to puncher a hole in my in-fill line that feeds the circulated water from the resiour, mounting an inverted funnel, so no dirt gets in, that would suck air into the line before it gets to the falls. Will I need a one way valve or will the waters flow suck in more air than water escaping? I could start with a small hole I suppose. Short of doing so, what do you think?
Thanks, that confirmed my hesitation.
Thanks again
10K
  • · Replies 20 ·
  • · Replies 17 ·
