What Are the Spring Constant and Mass in This SHM Problem?
The spring constant for the given problem is calculated to be 88.89 N/m, derived from the potential energy formula PE = 1/2 * k * x^2, where PE is 1.0 J and x is 0.15 m. The mass attached to the spring is determined to be 0.95 kg using Newton's second law, relating maximum acceleration of 14 m/s² to the force exerted by the spring. The calculations confirm that the spring force and human force differ only in direction, validating the use of conservative force principles.
  • Understanding of Hooke's Law and spring potential energy
  • Familiarity with Newton's second law of motion
  • Basic algebra for rearranging equations
  • Knowledge of simple harmonic motion concepts
  • Study the derivation of Hooke's Law and its applications in mechanics
  • Learn about energy conservation in conservative systems
  • Explore advanced topics in simple harmonic motion, including damping and resonance
  • Investigate real-world applications of springs in engineering and physics
Students studying physics, particularly those focusing on mechanics and oscillations, as well as educators seeking to enhance their understanding of spring dynamics and simple harmonic motion.
foggy
i need help...
A mass sitting on a horizontal, frictionless surface is attached to one end of a spring; the other end is fixed to a wall. 1.0 J of work is required to compress the spring by 0.15 m. If the mass is released from rest with the spring compressed, it experiences a maximum acceleration of 14 m/s^2.
i need to find:
a) The value of the spring constant.
b) The value of the mass.
if anyone can help, i would really appreciate it.
Remember that for a mass under the action of a "conservative force" such as the spring force, the change in potential energy is equal to minus the work done on the mass.
Little but important detail: In order to use this fact in your problem, it is necessary to suppose that the mass as been compressed at constant and infinitely small speed, such that we can assert that if the work done by the human force in compressing the mass by 0.15 m is 1.0 J , then the work done by the spring force in compressing the mass by 0.15 m, must be -1.0 J** !
Supposing this condition is met, then the equation
[tex]\Delta U = - W[/tex]
should be helpful, if you remember that [itex]U_{spring}=\frac{1}{2}kx^2[/itex]. As for the part concerning the acceleration, recall how Newton's second law relates force, mass and acceleration.
**You can probably convince yourself of that by considering that under these conditions, the force of spring and the human force differ only in direction, and thus, only is sign!
P.S. You're better off showing us what progress you've made so far in your problems, so we are more able to focus on the points you're having difficulty with.
Sure, I'd be happy to help you with this simple harmonic motion problem. To start, let's review the formula for the potential energy stored in a spring:
PE = 1/2 * k * x^2
Where PE is the potential energy, k is the spring constant, and x is the displacement of the spring from its equilibrium position. In this problem, we are given the potential energy (1.0 J) and the displacement (0.15 m). So, we can rearrange the formula to solve for the spring constant:
k = 2 * PE / x^2
Plugging in the values, we get:
k = 2 * 1.0 J / (0.15 m)^2 = 88.89 N/m
So, the value of the spring constant is 88.89 N/m.
Now, let's move on to finding the mass. We can use Newton's second law of motion to relate the maximum acceleration (14 m/s^2) to the mass and the force exerted by the spring:
F = m * a
Where F is the force, m is the mass, and a is the acceleration. In this case, the force is provided by the spring and is equal to the spring constant times the displacement (x):
F = k * x
So, we can rewrite Newton's second law as:
k * x = m * a
88.89 N/m * 0.15 m = m * 14 m/s^2
Solving for m, we get:
m = (88.89 N/m * 0.15 m) / 14 m/s^2 = 0.95 kg
Therefore, the mass is 0.95 kg.
I hope this helps you solve the problem. Remember to always carefully read and understand the given information and use the appropriate formulas to solve for the unknown values. Best of luck!
  • · Replies 20 ·
