| New Reply |
Problem of Calculus: derivative, i guess logarithmic differentiation |
Share Thread | Thread Tools |
| Jun9-12, 10:16 PM | #1 |
Image of the problem: http://prntscr.com/addkf 2. Relevant equations My question is how I can solve the equation I gave above. Should I use logarithmic differentiation? Because I think that the logarithmic differentiation is used when y = (the equation) but my problem is f (x) = (the equation). 3. The attempt at a solution Possible solutions: http://prntscr.com/addwu |
| Jun9-12, 10:42 PM | #2 |
try using (f+g)'=f'+g', then use logarithmic differentiation for f and g separately.
In your link to worked example, first option is wrong because you never took derivative in sense of a^(5x-1) for instance. Second option is wrong because Log does not distrubute across addition like that. |
| Jun10-12, 05:31 PM | #3 |
What about this possible solution to the problem:([itex]x^{(5x-1)}[/itex][itex]\frac{5x-1}{x}[/itex]+5lnx) - 2x[itex]e^{(11-x^2)}[/itex]
| Jun10-12, 07:20 PM | #4 |
Mentor
Problem of Calculus: derivative, i guess logarithmic differentiationIt really helps us, if you make your images visible in your post. The [itex]\displaystyle -2x\,e^{11-x^2}[/itex] is the derivative of [itex]\displaystyle e^{11-x^2}.[/itex] |
| Jun10-12, 10:14 PM | #5 |
I attach the procedure for which i got the result, i need that someone say me if i am right or wrong.
Thanks to all the members that comment in my thread and try to help me. |
| Jun10-12, 10:39 PM | #6 |
Mentor
Yes, that answer looks fine ! |
| Jun12-12, 05:25 PM | #7 |
Mentor
So, I gave the x5x-1 term to WolframAlpha to differentiate.
WolframAlpha did not use logarithmic differentiation. Instead, it used the following scheme. Suppose we have a function that can be expressed in the following way,For the case of [itex]\displaystyle f(x)=x^{5x-1}\,,[/itex] we have [itex]\displaystyle g(u,\,v)=u^v\,,[/itex] where [itex]\displaystyle u(x)=x\,,[/itex] and [itex]\displaystyle u(x)=5x-1\,.[/itex] ∂g/∂u treats the function g, as if the base of the expression, in this case x by itself, is the part with the variable, and treats the exponent as being constant, as is the case of a power function. ∂g/∂v treats the exponent of the expression, in this case x by itself, as being the part with the variable, and treats the base as being constant, as is the case of an exponential function. |
| New Reply |
| Thread Tools | |
Similar Threads for: Problem of Calculus: derivative, i guess logarithmic differentiation
| Derivative implicit differentiation problem | Calculus & Beyond Homework | 4 | ||
| Logarithmic Differentiation Problem | Calculus & Beyond Homework | 7 | ||
| Logarithmic differentiation | Calculus & Beyond Homework | 5 | ||
| Differentiation, Second Derivative, of Functions Problem | Calculus & Beyond Homework | 4 | ||
| help on logarithmic differentiation problem | Calculus & Beyond Homework | 8 | ||
