What are the equations of motion for a rotating disc on a fixed axis?
The discussion focuses on deriving the equations of motion for a uniform disc of mass m and radius a, rotating about a fixed horizontal axis in a vertical plane. The angle θ is measured from the downward vertical, and the behavior of the disc is compared to that of a pendulum. Key points include the importance of the diagram's accuracy in determining the direction of angular acceleration and velocity, as well as the convention used for measuring angles. The participants clarify that angular acceleration can be considered negative when the body slows down as it moves upward.
  • Understanding of rotational dynamics and angular motion
  • Familiarity with pendulum motion and its characteristics
  • Knowledge of vector quantities, specifically acceleration and angular velocity
  • Ability to interpret and analyze diagrams in physics
  • Study the derivation of equations of motion for a pendulum using Lagrangian mechanics
  • Learn about the effects of angular displacement on torque and angular acceleration
  • Explore the relationship between linear and angular motion in rigid bodies
  • Investigate the impact of friction and air resistance on pendulum motion
Students and educators in physics, mechanical engineers, and anyone interested in the dynamics of rotating bodies and pendulum systems.
binbagsss
-See attached diagram
- A uniform disc of mass m and radius a is free to rotate in a vertical plane about a fixed smooth horizontal axis, the axis passes through the mp A of the radius of the disc.
- It then asks you to dervie equations of motion for when AO makes an angle pheta with the downward vertical ( and to find the force perpendicular to AO when AO is in this position)
To get the correct solution, the diagram needs to be correct - if I'm correct, as this determines whether the mass is speeding up or down, as if the angle was on the opposite side, the mass would INSTEAD be speeding up - which changes everything.
I have a few questions in how exactly the question specifies some details of the diagram
1) The angle with the downward vertical, why is it not the other side - is this convention, as in when they specify pheta with the downward vertical it is the counter clockwise direction.
2) Why is the angular acceleration not negative - as the body slows down as it goes upward.(Actually, I assume this is relative to the equation itself, as if you did this, you would get the same for Y , taking mg as negative)
3) To the diagram I have added a direction for the angular velocity - is this correct? Also if you choose to do this, shouldn't the angular acceleration be drawn in the opposite direction?
I don't understand the bit in bold.
theta
If I have this right - the disk is hanging from a point on it's edge so it can swing like a pendulum.
The disk will normally hang motionless if AO is vertical - so this is a natural choice for the zero angle. You can pick anything you like but it makes the math easier if you let the physics suggest the choice.
Acceleration is a vector. Acceleration can be negative when an object slows down, or if it speeds up in the negative direction.
Before I can comment properly I need to be sure I have understood what the diagram represents.
If you displace a pendulum anticlockwise by some angle θ, and let go, it's initial angular velocity will be zero and it's acceleration will be a maximum pointing clockwise. Does that help? From what I understand about this description your disc will behave like a pendulum.
  • · Replies 25 ·
