Ti-84 strange derrivative problem
  • Context: Undergrad
  • Thread starter Thread starter Bassie
    Strange Ti-84
The forum discussion centers on using the Ti-84 calculator for calculating derivatives, specifically using the nDeriv function. The user encountered discrepancies when differentiating trigonometric functions like sin(x) and cos(x), leading to incorrect results. The issue was identified as a misinterpretation of the angle measurement, where the calculator was set to degrees instead of radians. Ensuring the correct mode is crucial for accurate derivative calculations in trigonometric functions.
  • Understanding of derivative concepts and notation
  • Familiarity with the Ti-84 calculator functions
  • Knowledge of trigonometric functions and their derivatives
  • Awareness of angle measurement units (degrees vs. radians)
  • Learn how to switch between degrees and radians on the Ti-84 calculator
  • Explore the use of the nDeriv function in more complex functions
  • Study the properties of derivatives for trigonometric functions
  • Practice calculating derivatives using both symbolic and numerical methods
Students, educators, and anyone using the Ti-84 calculator for calculus, particularly those working with trigonometric functions and derivatives.
Bassie
Hey there, I'm using a Ti-84 calculator to calculate derrivatives.
It goes like this:
Y1={the actual function}
Y2=nDeriv(Y1,X,X)
This seems to work, except for functions with cos(x), sin(x),..
Example:
Y1=X²
Y2=nDeriv(Y1,X,X)
Y3=2X
As Y3 represents the actual derrivative of Y1, Y2 and Y3 are the same.
But when I enter the following:
Y1=sin(X)
Y2=nDeriv(Y1,X,X)
Y3=cos(x)
As cos(x) is the derrivative of sin(x), Y2 and Y3 should be the same. But they aren't.
For X=3, I get:
Y1=0.258819045103
Y2=0.016858586
Y3=0.965925826289
Does anyone have an idea what I'm doing wrong? Thanks in advance.
E: I think I found the solution myself. It seems that X was considered as a degree value instead of a radian value!
For X=3, I get:
Y1=0.258819045103
Y2=0.016858586
Y3=0.965925826289
It is important to make sure whether you are working with degrees or radians. But the results are not correct. Y1 and Y3 are consistent with X = 15°, not 3.
