New Reply
Need help on finding the work done on an Object by the applied force.
Share Thread Thread Tools
Jun12-12, 10:11 PM   #1
"A 50 kg crate is being dragged across a floor by a force of 225 N at an angle of 40° from the horizontal. The crate is dragged a distance of 5.0 m and the frictional force is 60 N."
Now from that information i am supposed to find the work done by the applied force on the object.
This is what i have so far. Since W= (F cos θ)Δd, i did W= (225 N cos 40°)5.0 m ≈ 862 N.m
Am i correct
PS this is my first time on physics forum. :)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun13-12, 03:28 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
hi xuhhad! welcome to pf!
Quote by xuhhad View Post
Am i correct
yes
(what is worrying you about that?)
Jun13-12, 04:47 AM   #3
Recognitions:
yep - hi xuhhad! welcome to PF!
It can be a bit daunting at first - especially when an answer seems to come too easily. As you learn more you'll be able to develop strategies to figure out if you are right or not without having to ask anyone.
I suppose it next asks for the work done by the frictional force?
Jun13-12, 12:23 PM   #4
Yes it does :/
and again i am stuck sorry for the inconvenience. I really need help.
Jun14-12, 04:33 AM   #5
Recognitions:
Funny that :) You have to think it through - what is the definition of work in terms of force? Can you write it in words?
Jun14-12, 04:43 AM   #6
Recognitions:
hi xuhhad!
you seem to have a lack of confidence
but your original answer, using the correct definition of work done, was fine, so just do the friction in exactly the same way, and then that'll be fine too!
what do you get?
Jun14-12, 08:50 PM   #7
Quote by Simon Bridge View Post
hmm the work formula would be W=mg/Δd
Jun15-12, 01:21 AM   #8
Recognitions:
Get used to putting the formulas into words and thinking about what they mean.
Your formula has work equal to the vertical force divided by the displacement ... which would mean that the further you drag the crate, the less energy is taken by friction ... does that sound right?
Aren't you also lifting the crate a bit as you pull it? Does that matter?
(Since you have not been given dimensions for the crate, I expect that you are to treat all forces through the center of mass?)
Jun15-12, 02:57 AM   #9
Recognitions:
no, work done = force "dot" displacement
(so it can be positive or negative)
learn this definition!!
Jun17-12, 05:10 PM   #10
i still don't understand how i can find the frictional force.
Jun17-12, 05:26 PM   #11
Recognitions:
the frictional force is given in the question …
it's 60 N horizontally, "backwards"
Jun18-12, 11:12 PM   #12
OHHHH
i get it i just have to use the work formula again, something like this correct
W=(-Ff)cos θ * Δd
Thak u for all the help
Jun18-12, 11:25 PM   #13
Yes it does :/
F_kinetic = μ_k F_normal
Does that help?
Jun18-12, 11:41 PM   #14
Am i correct
Yes...
This part of your question sounds like:
The problem
A=1, B=2, AB
Relevant equations
AB=AB
Solution
AB=(1)(2)=2
Am I correct?
P.S. I'm not hijacking this thread. I obviously know what 1 multiplied by 2 is. I'm just saying that the problem I wrote is very similar to the problem given by the OP.
Jun18-12, 11:41 PM   #15
Quote by dimension10 View Post
Does that help?
Yes thank u for posting i already completed the question thank u for the help though
Jun18-12, 11:42 PM   #16
Oh..
Aug4-12, 06:59 AM   #17
if the is a force acting opposite to the direction of motion of the crate ( frictional force= 60N) this implies that the total force pulling the crate is now; 225N - 60N =165N.
the reaction force to the floor will be= 50cos40=38.30N
Therefore, total pulling force= 165N - 38.30N= 126.7N.
Now Work done= 126.7 x 5 = 633.5J
New Reply
Thread Tools
Similar Threads for: Need help on finding the work done on an Object by the applied force.
Thread Forum Replies
need help visualizing what an object is doing with force applied Introductory Physics Homework 5
What is the applied force required to push an object up a ramp? Introductory Physics Homework 9
Quesiton on applied force on a rolling object Classical Physics 2
FInd the work done when a cnstant force applied to an object Precalculus Mathematics Homework 1
Finding work done on object with a chnaging force Introductory Physics Homework 1
