Is Moisture Harmful to Telescope Lenses in Cold Weather?
Moisture does not ruin telescope lenses in cold weather, but precautions are necessary to prevent condensation. Users should allow their telescopes to acclimate to outdoor temperatures by placing them in a garage or car before use. The discussion highlights the effectiveness of using a dew cap or covering the telescope with a plastic sheet to minimize moisture exposure. Additionally, users of the Meade ETX-105 should be aware that cold temperatures can affect the adhesive of the diagonal flip-mirror, potentially leading to maintenance issues.
  • Understanding of telescope acclimatization techniques
  • Knowledge of dew caps and their function
  • Familiarity with the Meade ETX-105 telescope model
  • Basic maintenance skills for telescope components
  • Research telescope cooling techniques for optimal performance
  • Learn about different types of dew caps and their effectiveness
  • Explore maintenance tips for the Meade ETX-105, focusing on adhesive issues
  • Investigate the impact of temperature on optical equipment
Astronomy enthusiasts, telescope owners, and anyone interested in maintaining optical equipment in cold weather conditions.
redrum781
i just bought a telescope and i am in Canada it iz really cold outside and i want to take it outside to look at the stars but someone told me that moisture would get stuck in the lens and it would be ruined can somebody tell me if this is true personally i don't think it would but i don't want to take a chance of ruining it right away
Astronomy news on Phys.org
no it should not ruin the lens
if you can put the scope in a place that it will cool befor you go out to use it
like a garage or in a car as the hot scope will attract water from cold air
that will make it hard to see thru it
most good seeing is in cold clear weather so everone has this problem
a cover called a dew cap is a good idea too
or you can cover the whole scope with a plastic sheet
when waiting for it to cool
I have a relatively new Meade ETX-105 and have used it in cold weather (about 15F). One problem (besides frostbite) is the adhesive holding the diagonal flip-mirror in place loses its stickiness and can fall off. Its not difficult to fix yourself if that happens, but it was scary/annoying for a new scope to have that problem.
  • · Replies 25 ·
