Gas flow, time required to fill a tank
The discussion revolves around the problem of filling a box with carbon dioxide from a tank, focusing on the time required to achieve this. Participants explore various aspects including gas laws, flow rates, and the conceptual understanding of gas behavior in a container.
  • One participant uses the ideal gas law (PV = nRT) to calculate the volume of CO2 in the tank and seeks to determine the time to fill a box with this gas.
  • Another participant proposes a method to estimate the flow rate of CO2 based on pressure and density, suggesting different results depending on the pressure used (40 kPa vs. 4500 kPa).
  • Concerns are raised about the lack of a specified desired pressure in the box, which complicates the understanding of how much gas is needed to fill it meaningfully.
  • A participant expresses uncertainty about the conceptual aspects of filling the box, particularly regarding the behavior of CO2 in the absence of a lid and the potential for gas to escape.
  • Another participant suggests estimating the amount of CO2 needed to replace the air in the box and emphasizes the importance of measuring the box's volume to apply the gas law correctly.
Participants do not reach a consensus on the best approach to determine the time required to fill the box with CO2. Multiple competing views and uncertainties remain regarding the necessary conditions and calculations involved.
Participants highlight limitations such as the need for specific measurements (e.g., volume of the box) and the assumptions regarding pressure and density when calculating flow rates. The discussion also reflects varying levels of understanding and conceptual clarity among participants.
This discussion may be useful for individuals interested in gas dynamics, experimental physics, or those seeking to understand the practical applications of gas laws in real-world scenarios.
jnesbit
Hi all,
I've been searching through the forum, and found some related posts, but still can't wrap my head around this. I would greatly appreciate any help.
I'm trying to fill a box with carbon dioxide from a tank, that has attached to it a regulator and tube.
I used PV = nRT to find the volume of CO2 inside the tank; here are all my variables:
P (inside tank) = 4601.325 kPa
V (inside tank) = 0.273 cubic meters
n = 515.32 moles
R = 0.0083 (m3*kPa/mol*K)
T = 293 K
I want to know how long it would take to fill a box with CO2 from this tank. The regulator on the tank shows the pressure inside the tank is 4,500 kPa and the pressure of CO2 exiting the tank is 40 kPa. The diameter of the tube through which CO2 exits the tank is 1/8 inch.
I've taken 3 non-calculus-based physics classes, and passed thanks to some hideous curve. So I'm trying to escape this dumbed-down understanding my university has so graciously given to me...
Thank you!
Nathan
Science news on Phys.org
I've no idea whether this is right, but I tried this:
Treat the 40kPa acting over the area of the pipe as a force accelerating the gas up to its flow speed. By conservation of energy, the linear speed that results is √(2P/ρ) where P is the pressure and ρ the density. For a volumetric rate that's A√(2P/ρ). Question is, what pressure and density? Using the 40kPa and ρ = 2kg/m3, it gives 1.6 litres/s. Using the 4500 kPa gives 10 times that.
This assumes the pipe is very short. For a longer pipe you have to take into account the pressure gradient along it.
jnesbit said:
Hi all,
"Filling a box" with gas is not meaningful unless you specify the desired pressure of the gas in the box. Otherwise, any amount of gas, no matter how much, will expand to "fill the box" in the sense that it will occupy the entire volume of it.
The desired pressure of the gas in the box... good point. I guess I thought even though a gas would fill the box, there would still be a "normal" density/volume it would occupy. Sort of like a saturation point, where it wouldn't be building pressure, and it wouldn't be "loose."
My problem might be more of a conceptual one; there is no lid to the box. I'm just basically lowering the CO2 tube into the box, letting it run for a few minutes, and then removing it. I'm hoping that the stagnant air in the room, plus the density of CO2 being greater than air, will at least somewhat contain the CO2 in the box.
If this is something that would require a doctorate in physics, like to understand the movement of air particles and "how much is enough" in order to keep a reasonable amount of CO2 in the tank while allowing for a minimum amount to spill out, so as to waste as little CO2 as possible... I can just keep doing what I've been doing, which is run the CO2 for 2-4 minutes and hope for the best.
OK, I thought you may want to do something like this.
As you say, this is not a stable state. Some CO2 will leak out in time.
However you can estimate how much CO2 you need to replace the air in the box (initially full with air).
The volume of the CO2 is the volume of the box. You need to measure this, you cannot calculate it from the gas law.
Then you can take the pressure equal to atmospheric pressure and temperature equal to the room temperature at location.
Then from the gas law you can fin how many moles of CO2 in normal conditions will fit in the box. You can also find the mass of CO2 if you multiply number of moles by molecular mass (44 g/mole for CO2).
To find the time you will need to know the flow rate of your source (either volume, mass, molar).
9K
  • · Replies 18 ·
13K
