Solving Momentum Problem with Caroline Hallisey & Alyson Dudek
  • Thread starter Thread starter BlasterV
    Momentum
The discussion revolves around a momentum problem related to a short-track speedskating relay event, specifically focusing on the interaction between two skaters, Caroline Hallisey and Alyson Dudek, during a collision. The problem involves calculating the velocities of both skaters after a push, utilizing principles of momentum and impulse.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the application of conservation of momentum and impulse to determine the velocities of the skaters post-collision. There are attempts to clarify the calculations involved and to verify the correctness of the results obtained by different participants.
Multiple interpretations of the problem are being explored, with some participants questioning the accuracy of the calculated velocities. Guidance is offered regarding the use of impulse and conservation of momentum, but there is no explicit consensus on the correct approach or final answers.
Some participants note the potential influence of external forces, such as friction with the ground, which may not be accounted for in the calculations. There is also mention of the need for specific mass values, which are provided, but the implications of these values on the calculations are still under discussion.
BlasterV
One sport at the Winter Olympics is short-track speedskating. The relay event features teams of four skaters in a long race. Each team member typically skates one or two laps, then passes the race to another member. Instead of handing the teammate a baton, however, a skater must simply touch the teammate. Skaters are trained to collide with the next skater, in order to give him or her a big push.
Consider this year's US Speedskating Women's relay team. Caroline Hallisey is just finishing her lap, moving at 11.17 m/s, and runs into Alyson Dudek, who is at rest. If Caroline stops dead, how fast will Alyson move forward?
14.4167594178 m/s - Correct.
(Yes, you need to know their masses. Go look them up. If you can't find them after 10 minutes of searching, let me know. You should find that Caroline's mass is larger than Alyson's mass).
Caroline is 60.3kg - Correct.
Alyson is 46.72kg - Correct.
Suppose that Caroline is again moving at 11.17 m/s, and again preparing to push Alyson. This time, however, Caroline pushes Alyson forward as hard as she can during their brief encounter: Caroline exerts an average force 1200 N on Alyson over a duration of .75 seconds.
Now how fast does Alyson leave the starting line after the collision?
22.8264024752 m/s - Correct.
What is Caroline's velocity after the collision?
Here is where it goes to hell, I done this over 6 different ways and got it wrong, and because of that I really can't show work because it wouldn't really be going anywhere (I am at the point where I have no idea what's wrong). I tried to use the Conservation of momentum equations and it didn't work for me.
Can someone show me how to do this part step by step and give an answer (so after I solve I know if I'm agreeing with the right answer)
Thanks a lot.
Hi BlasterV,
Are you sure that your answer of 22.83m/s for Alyson's velocity is correct? After the following calculation, I got a different answer:
Impulse = Change in Momentum = Force * Time
I = Ft
I = 1200 * 0.75 = 900Ns
This is Alyson's momentum after being pushed by Caroline, i.e.
mv = 900Ns
v = 900 / 46.72 = 19.26m/s
Then by conservation of momentum;
m1u1 = m1v1 + m2v2
where m1 is Caroline's mass, u1 is Caroline's initial velocity, v1 is her final velocity, m2 is Alyson's mass and v2 is Alyson's final velocity
60.3 * 11.17 = 60.3 * v1 + 900
60.3 * v1 = -226.449
v1 = -3.755m/s
i.e. Caroline moves at 3.755m/s in the opposite direction to Alyson
An alternative way of considering this second part is to use Newton's third law (every action has an equal and opposite reaction). Therefore the force acting on Caroline is also 1200N for 0.75s and the change in her momentum is -900Ns (negative since it is in the opposite direction). Then her final momentum is:
11.17 * 60.3 - 900 = -226.449
mv = -226.449
v = -3.755m/s
Hope that helped (and also that I haven't made some mistake :smile: )
Chris
Answer 1: There is not enough information. Caroline will be pushing off on the ground while pushing on Alyson.
Answer 2:
Conservation of momentum:
[tex]m_{a}v_{a0}+m_{c}v_{c0}=m_{a}v_{a1}+m_{c}v_{c1}[/tex]
Fill in the known quantities:
[tex]m_{a},m_{c},v_{a0},v_{c0},v_{c1}[/tex]
Using rough values:
[tex]40kg(0\frac{m}{s})+60kg(10\frac{m}{s})=40kg(20\frac{m}{s})+60kg(v_{c1})[/tex]
simplify and solve
[tex]600\frac{mkg}{s}=800\frac{mkg}{s}+60kg v_{c1}[/tex]
[tex]-\frac{200\frac{mkg}{s}}{60kg}=v_{c1}[/tex]
[tex]v_{c1} \approx -3 \frac{m}{s}[/tex]
Chris, I submit homework to an online thing that says if its right or not, 22.8 etc is definitley right, but I'll try using my number with what you did
No. How did you come up with this answer?
Chris's answers are correct.
Making the assumption that during the collision of the two skaters the only forces that you need consider are what they exert on each other, then you can find the change in velocity by considering the impulse:
Impulse on Alyson: [itex]F \Delta T = m_A \Delta v_A[/itex], solve for [itex]\Delta v_A[/itex].
The impulse on Caroline is equal and opposite to the impulse on Alyson:
[itex]-F \Delta T = m_C \Delta v_C[/itex], solve for [itex]\Delta v_C[/itex].
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 40 ·
