Rotating Object Transformation: Length/Circumference Change?
  • Context: Graduate
  • Thread starter Thread starter Jakedasnake
    Rotating Transformation
The discussion centers on the relativistic effects experienced by a rotating disc-like object moving at approximately 0.86c, specifically regarding length contraction along the axis of rotation and circumference as observed. Participants highlight that at such speeds, a rigid disc would experience significant stresses, potentially leading to structural failure, while a deformable disc's behavior may depend on its material properties. The concept of non-Euclidean geometry is introduced, emphasizing the complexities of modeling such a system accurately. The Ehrenfest paradox is referenced as a key theoretical framework for understanding these phenomena.
  • Understanding of special relativity and length contraction
  • Familiarity with the Ehrenfest paradox
  • Knowledge of material properties under high-stress conditions
  • Basic principles of non-Euclidean geometry
  • Study the implications of special relativity on rotating bodies
  • Research the Ehrenfest paradox in detail
  • Explore material science related to high-speed rotational dynamics
  • Investigate non-Euclidean geometry applications in physics
Physicists, engineers, and students interested in the effects of relativistic speeds on rotating objects, as well as those exploring theoretical models in advanced physics.
Jakedasnake
If a disc-like object was rotating so that its outside edge was at about 0.86c (causing a factor of change of about 2) relative to an observer, then would it contract in length along the axis of rotation, or the circumference (relative to the observer)? in other words, would it get thinner or smaller?
Please correct me on any mistakes I made because I have next to no knowledge on this subject, I just need this information for a thought experiment I've been working on.
Why do you think the wheel would contract at all?
See: http://en.wikipedia.org/wiki/Ehrenfest_paradox
Spinning up a rigid disc from rest would brake it. For a deformable disc I'm not sure if radial contraction is possible due to centrifugal forces. It might depend on the assumed theoretical material properties. Real world materials would break way below this speeds.
But you can build an already spinning disc from rigid elements. The geometry described by those rigid elements is non-Euclidean.
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 24 ·
  • · Replies 29 ·
