Anti-Helmholtz coil configuration
  • Context: Graduate
  • Thread starter Thread starter Niles
    Coil Configuration
The discussion centers on the magnetic field configuration produced by two coils arranged in an anti-Helmholtz configuration, specifically focusing on the field along the x-direction. Participants explore the implications of Maxwell's equations in this context and the mathematical representation of the magnetic field.
  • One participant seeks to understand the magnetic field along the x-direction, given the known field along the z-direction, and questions if B(x) is simply -B(z).
  • Another participant clarifies that the divergence of the magnetic field (div B = 0) leads to a relationship between the derivatives of the components of the magnetic field, suggesting that symmetry implies equal behavior in the x and y directions.
  • This participant argues that the derived relationships do not yield a specific magnetic field value but rather describe the behavior of the field's derivatives at a point, particularly along the central axis.
  • A third participant introduces the concept of off-axis fields from current loops, mentioning that these can be expressed using elliptic integrals and that the total field from a pair of coils is a sum of the individual fields.
  • References to advanced texts for more extensive derivations and explanations are provided, indicating that the topic may require deeper exploration in specialized literature.
Participants express differing views on the implications of the mathematical relationships derived from Maxwell's equations, with no consensus reached on the specific nature of the magnetic field along the x-direction.
The discussion highlights limitations in deriving specific magnetic field values from the relationships presented, as well as the dependence on symmetry and the central axis of the coils.
Niles
Hi
Say I have to coils in the anti-Helmholtz configuration as in the attached picture. It is pretty easy to find the field along the z-direction, as this is introduced in introductory EM. However say that I would like to know the field along the x-direction. This I don't know how to find.
What I *do* know is that the Maxwell Equations (div B = 0) tell me that
[tex] \frac{dB}{dx} = \frac{dB}{dy} = -\frac{1}{2}\frac{dB}{dz}[/tex]
But does this imply that the field along x, B(x), is simply -B(z), the negated B-field along the z-direction?
Niles.
div B = 0 is equal to [itex]\frac{\partial B_x}{\partial x} + \frac{\partial B_y}{\partial y} = - \frac{\partial B_z}{\partial z}[/itex]
Using symmetry, x and y must be the same, therefore [itex]\frac{\partial B_x}{\partial x}= - \frac{1}{2}\frac{\partial B_z}{\partial z}[/itex]
This does not give you any magnetic field! It is just the derivative of the field at some specific point - probably along the central axis. Looking at the (x,y)-plane right in the middle of the coils, you have a field going radially inwards/outwards (depending on the orientation).
Thanks, that was kind of you.
The off-axis field from a current loop is written as an expansion in elliptic integrals (or sometimes other functions, depending on the coordinate system you choose). Here is a site that came up in a Google search for off-axis field from a loop:
http://www.netdenizen.com/emagnettest/offaxis/?offaxisloop
but there are many others. The field from a pair of coils is then a sum of the fields from the individual loops.
More extensive derivations/explanations are found in advanced E&M texts like those by Jackson, Smythe, and Stratton.
  • · Replies 17 ·
  • · Replies 16 ·
