Universe Expansion = Drop in Gravity ?
The discussion revolves around the relationship between the expansion of the universe and gravitational forces. Participants explore whether the expansion is due to a decrease in gravitational forces or if it is driven by other factors, such as dark energy. The conversation includes theoretical implications and speculative reasoning regarding the nature of gravity and expansion.
  • Some participants propose that the universe's expansion could be linked to a drop in gravitational forces, questioning what might cause such a drop.
  • Others argue that the expansion is not related to a decrease in gravitational forces, noting that gravity does not drop and that local gravitational effects counteract expansion.
  • It is suggested that the expansion of the universe is accelerating due to dark energy, which is still not well understood.
  • Some participants clarify that dark energy is not a force but a label for the phenomenon causing the acceleration of expansion, similar to the concept of the Coriolis Force.
  • A later reply introduces the idea that dark energy has a constant negative pressure, leading to an increase in repulsive gravity as space expands, which was unexpected in the context of cosmic expansion.
Participants generally disagree on the relationship between gravitational forces and the expansion of the universe. While some assert that dark energy is the primary driver of expansion, others question the implications of gravitational forces in this context. The discussion remains unresolved regarding the exact nature of these forces and their interplay with cosmic expansion.
There are limitations in the understanding of dark energy and its role in the universe's expansion, as well as the assumptions about gravitational forces and their effects at large distances. The discussion reflects a range of hypotheses and uncertainties without definitive conclusions.
blackskynet
Universe is expanding but is it due to drop in gravitational forces all over in the universe ?
Gravitational force holds all the objects together in the universe ...?
Universe is expanding means one object is moving away from another, Is this due to drop in Gravitational force ? If Yes, then what causes gravitational forces to drop ?
Space news on Phys.org
The expansion was initially believe to be slowing due to the density of the matter in the universe decreasing, meaning that things were getting further apart and thus their gravitational attraction to each other was lessening due to increased distance. However the expansion is now believed to be accelerating, which is hypothesized to be due to something called "dark energy" which we still know very little about.
No, it is not believed that expansion has anything to do with a drop in gravitational forces.
Gravitational forces are not observed to drop. In fact, locally, gravity counteracts the expansion : the Solar System does not expand.
The expansion is only observed for objects separated by very large distances, distances at which gravity has no effect.
I'm not sure we have a good understanding of what exactly is causing the expansion.
As already stated, the expansion is from dark energy, not the weakening of gravity. If that were true, galaxies, solar systems, stars, and planets would all start slowly falling apart, since the other three forces do not play a role in keeping the together.
Dark energy is not meant to explain the expansion itself, but rather the acceleration of the expansion.
Even further: Dark Energy is not an explanation at all. It is simply the label we have given to whatever it is that is causing the expansion. If you do the bookkeeping right, you can express the acceleration of the expansion as a force, but that does not mean that what is causing it is actually a force or a form of energy.
Think of something like the Coriolis Force. That is a label made up to describe something in useful (if not accurate) terms. In a rotating FoR, we see things move as if there were a force applied, but that does not mean it is a force causing it. Coriolis Force does not explain why or how the objects move the way they do; it is simply an operation that needs to be applied, an operation that can be expressed in terms of forces.
It is the same with Dark Energy.
It's crazier than that!
Note that the 'vacuum' of space where dark energy resides has a constant negative pressure...meaning a type of expansive, repulsive gravity. So as 'space expands', a bit of a misnomer, a constant dark energy density means the overall repulsion increases as the volume of space gets bigger! [yes, an 'infinite' universe could still expand.] So repulsive gravity is increasing with time! Nobody expected THAT until Edwin Hubble examined the heavens from Mount Wilson observatory and found expansion.
In the past more dense 'matter' [galaxies, stellar dust, black holes, planets,radiation, etc] was able to keep expansion slower..but as stuff moves apart, dark energy prediominates. So we are now in an energy dominated accelerated xpansion.
So this 'hypotheitical explanation' is [a] weird and one we know little about.
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 39 ·
  • · Replies 24 ·
  • · Replies 23 ·
