IR Distance Sensor: Will this receiver work?
The discussion centers on the "Ambient Light Ignoring Infrared Active Distance Sensor," which utilizes an LM555 timer to generate a 5kHz frequency and a modified receiver circuit featuring a common emitter setup with an NPN phototransistor. Key modifications include replacing the RLC circuit with an Inverting Band Pass Filter and allowing all voltages to pass through the receiver, enabling continuous voltage monitoring based on distance. The user seeks confirmation on whether the output voltage will still function despite the removal of specific components, including operational amplifiers and capacitors, and whether the output voltage will vary with distance.
  • Understanding of LM555 timer operation
  • Knowledge of NPN phototransistor functionality
  • Familiarity with Inverting Band Pass Filter design
  • Basic principles of voltage monitoring in electronic circuits
  • Research "Inverting Band Pass Filter design" for improved circuit performance
  • Explore "NPN phototransistor applications" for enhanced sensor capabilities
  • Study "LM555 timer frequency generation" for optimized timing circuits
  • Investigate "voltage monitoring techniques" for accurate distance measurement
Electronics enthusiasts, mechatronics students, and engineers involved in sensor design and development, particularly those focusing on infrared distance sensing technologies.
CognitiveNet
I've developed a new concept called "Ambient Light Ignoring Infrared Active Distance Sensor". It consists of a transmitter with an infrared LED which uses a traditional LM555 timer to oscillate a frequency of 5kHz and a modified receiver which consists of a common emitter setup, NPN phototransistor and a filter.
What I've done with the receiver is to replace the RLC circuit with an Inverting Band Pass Filter circuit and removed a significant part of what once was a receiver for a motion detector. Originally the circuit was designed to only allow negative voltages to pass through the first operational amplifier in the receiver circuit, store the voltage in the C4 capacitor (as far as I'm concerned) and output a signal that sounds an alarm, when the voltage overcomes the threshold voltage (as far as I'm concerned). The new design is designed to allow all the voltages to pass through, in order to constantly monitor the voltage which would depend on the distance the infrared light travels from the transmitter.
(The 1N4148 diode's purpose is to make sure that the current only goes one direction, to i.e. prevent damage in the circuit).
So my question to you is following:
1) Will the voltage pass through the receiver circuit to output despite that I removed;
a) The operation amplifier of 50K which sets the threshold
b) The operational amplifier IC2B
c) The capacitor C2 which stores the negative voltage
d) The 22K resistor
2) Would the following apply also for my circuit despite the changes:
The voltage output would vary with the distance between the infrared LED/NPN phototransistor.
3) Do you agree that the difference between the motion detector and my distance sensor is that, I'm allowing all voltages to pass through instead of outputting a signal only if the voltage is high enough?
I've published all of the required information needed to answer my question on the following website:
http://cognitivenetwork.yolasite.com/
Note: The pictures are on the right, and the drawing bellow is of the original motion detector.
BE student in Mechatronical Engineering.
Do you still want help on this? Since the old link is broken, can you post a new link or Upload the schematic? Thanks.
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 24 ·
