How Is the Radius of a Critical Mass Sphere Calculated in Physics?
  • Thread starter Thread starter soyee7
    Physics
The radius of a critical mass sphere of neptunium-237 is calculated using the formula r = (3ρ / 4π)^(1/3), where ρ is the density of neptunium-237. Given that the critical mass is approximately 237 grams, the calculated radius is 3.75 centimeters. This calculation involves understanding the relationship between mass, volume, and density, specifically using the volume formula for a sphere, V = (4/3)πr^3. The final result confirms that the radius for a critical mass sphere of neptunium-237 is definitively 3.75 cm.
  • Understanding of basic physics concepts, particularly fissionable materials.
  • Familiarity with the formula for the volume of a sphere: V = (4/3)πr^3.
  • Knowledge of density calculations: ρ = m/V.
  • Basic algebra skills for rearranging equations and solving for variables.
  • Study the properties and critical mass calculations of other fissionable materials, such as uranium-235.
  • Learn about the implications of critical mass in nuclear physics and reactor design.
  • Explore advanced density and volume calculations in three-dimensional geometry.
  • Investigate the historical context and significance of research conducted at Los Alamos National Laboratory.
Students and professionals in physics, nuclear engineering, and anyone interested in the calculations related to critical mass and fissionable materials.
soyee7
I can't figure out how to get the answer with the given info, pleas help.
In the fall of 2002, a group of scientists at Los Alamos National Laboratory determined that the critical mass of neptunium-237 is about . The critical mass of a fissionable material is the minimum amount that must be brought together to start a chain reaction. Neptunium-237 has a density of .
What would be the radius of a sphere of neptunium-237 that has a critical mass?
Express your answer in centimeters to three significant figures.
google...read...think
Hi there, starting out in physics can be challenging, but don't worry, we've all been there! Let's break down the given information and see if we can figure out the answer together.
First, we know that the critical mass of neptunium-237 is given as a certain amount, but the question is asking for the radius of a sphere. This means we need to use some formulas and conversion factors to get from mass to radius.
Second, we are given the density of neptunium-237, which is measured in grams per cubic centimeter. This will be useful in our calculations.
To find the radius of a sphere, we can use the formula V = (4/3)πr^3, where V is the volume of the sphere and r is the radius. We can also use the formula for density, which is mass divided by volume (ρ = m/V). Since we are looking for the critical mass, we can set ρ to be equal to the critical mass given in the problem.
Now, let's plug in the values we know:
ρ = m/V
ρ = 237 g / V
We also know that the volume of a sphere is (4/3)πr^3, so we can substitute that in for V:
ρ = 237 g / (4/3)πr^3
To make things easier, we can rearrange the equation to solve for r:
r = (3ρ / 4π)^1/3
Now, we just need to plug in the values we know and solve for r:
r = (3 * 237 g / 4 * 3.14)^1/3
r = (711 g / 12.56)^1/3
r = (56.63)^1/3
r = 3.75 cm
Therefore, the radius of a sphere of neptunium-237 with a critical mass is approximately 3.75 cm. I hope this helps and keep up the good work in your physics studies!
12K
  • · Replies 16 ·
  • · Replies 0 ·
17K
11K
25K
