| New Reply |
Volume of Hot & Cold water required for a known volume and temperature |
Share Thread |
| Jun25-12, 05:38 PM | #1 |
I've just set a solar thermal array for research for my thesis. I would like to simulate different usage patterns to see how the system performs. I'm doing this using a Arduino with temperature sensors at the top hot the tank and on the cold supply which will then control a motorised valve which will dump hot water based on the usage patterns I set. I'm struggling to work out how to calculate this.
So for example if I want to dump 50l at 45°C and the hot water store is a 60°C and the coldwater supply is at 10°C. I need to work out the volume of hot and cold water required. (and tell the motorised valve to open for a time based on the volume calculated) I've been playing around with Q=mcΔT for a couple of day, and think I need to rearrange the equation to give me a ratio of the hot/cold water then calculate the actual volume based on how much I want to dump. Can anyone point me in the right direction? |
| Jun26-12, 12:40 AM | #2 |
Recognitions:
Desired temp = Td Hot temp = Th Cold temp = Tc Vol hot needed = V*(Td-Tc)/(Th-Tc) Vol cold needed = V*(Th-Td)/(Th-Tc) Is that what you're after? |
| Jun26-12, 03:21 AM | #3 |
Thanks haruspex!! That works.. I've just tested it experimentally
Do you know what I should look up to get a better understanding to this as where it was derived? |
| Jun26-12, 04:18 AM | #4 |
Recognitions:
Suppose Vol hot needed = Vh and Vol cold needed = Vc.
V = Vh + Vc The resulting temperature will be a weighted average of the two source temperatures: Td*V = Th*Vh + Tc*Vc Then it's just the standard process of solving two simultaneous equations. |
| New Reply |
| Tags |
| enthalpy change, mixing of water, solar thermal |
Similar discussions for: Volume of Hot & Cold water required for a known volume and temperature
| Calculating the Volume of Liquid as a fraction of the Volume of Gas for Water at 25°C | Introductory Physics Homework | 0 | ||
| Inrease in water pressure as a function of temperature under constant volume | General Physics | 4 | ||
| Water pressure, volume, temperature | Classical Physics | 1 | ||
| Temperature change of water at triple point in a constant-volume gas thermometer | Advanced Physics Homework | 0 | ||
| What is the relation between the volume of liquid water and temperature? | Introductory Physics Homework | 3 | ||
