| New Reply |
Directional Derivatives and Gradient question |
Share Thread | Thread Tools |
| Jun28-12, 11:49 AM | #1 |
Consider the surface and point given below:- Surface: f(x,y)= 4-x2-2y2 Point: P(1,1,1) a) Find the gradient of f. b) Let C' be the path of steepest descent on the surface beginning at P and let C be the projection of C' on the xy-plane. Find an equation of C in the xy-plane. 2. Relevant equations 1) ∇f = <fx , fy> 2) ![]() 3) ![]() 3. The attempt at a solution a) ∇f = <fx , fy> = <-2x, -4y> b)Descent means -∇f = <2x,4y> Subbing in P(1,1,1) -∇f = <2,4> ⇔ <1,2> Unit vector for descent, u = (1/√5) <1,2> ,where <1,2> is the direction vector of the descent gradient. I am really stuck here. I am not sure what they mean by the projection on the xy-plane. So are we moving from xyz to xy dimensions? And can I am not sure if I should use the projection formulas in this case or use derivatives to get the projection. Please help!! |
| Jun28-12, 02:02 PM | #2 |
I think that sometimes in this type of problem it helps to visualize a physical model. Suppose you have a thin metal plate and your ##f(x,y) =4 - x^2-2y^2## represents the temperature at the point ##(x,y)##, so the temperature at ##(1,1)## is ##1##. You are looking for the path to follow to cool off quickest. You have calculated that the direction to go at each point is ##-\nabla f = \langle 2x,4y \rangle##. From this you can conclude that the slope of the desired curve at ##(x,y)## is ##\frac{dy}{dx} =\frac {4y}{2x}=\frac {2y}{x}##. This is a simple first order differential equation. Do you know how to solve it? If so, the solution through ##(1,1)## is what you are looking for.
| New Reply |
| Tags |
| derivatives, descent, directional, gradient |
| Thread Tools | |
Similar Threads for: Directional Derivatives and Gradient question
| multivariable calculus, gradient, directional derivatives | Calculus & Beyond Homework | 0 | ||
| Problem with gradient vector, gradient, and directional derivative, etc. | Calculus & Beyond Homework | 1 | ||
| directional derivatives and the gradient vector | Calculus & Beyond Homework | 6 | ||
| Directional Derivatives and the Gradient Vector | Calculus & Beyond Homework | 2 | ||
| Gradient and Directional Derivatives | Calculus & Beyond Homework | 0 | ||
