New Reply
Calculating SHC of an alloy
Share Thread Thread Tools
Jun30-12, 01:20 PM   #1
I have done an experiment in which I measured the specific heat capacity of a coin. I would like to compare the results to the actual value. I have found out that the coin is made of Cupronickel alloy (for simplicity let's assume it's just 75% copper and 25% nickel).
SHC of copper: 0.39 kJ/kg K
SHC of nickel: 0.54 kJ/kg K
Knowing the SHC values of the two elements (copper and nickel) how would I go about calculating the theoretical value of the SHC of the Cupronickel alloy, so that I can compare it to my experiment's results?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jun30-12, 04:42 PM   #2
Recognitions:
Gold Membership Gold Member
Quote by Eleeist View Post
To do this, you need to know the Heat of Mixing, and how it varies with temperature.
New Reply
Thread Tools
Similar Threads for: Calculating SHC of an alloy
Thread Forum Replies
the alloy Atomic, Solid State, Comp. Physics 1
Calculating the diffusivity of hydrogen through an alloy coating on a steel container Introductory Physics Homework 0
Al-Cu Alloy Strength Engineering, Comp Sci, & Technology Homework 3
Aluminum alloy Grains, Which alloy is it? Materials & Chemical Engineering 1
