New Reply
How I can find U2 here ..
Share Thread Thread Tools
Jul1-12, 04:23 PM   #1
I will try
391.4368 + 24.264U2 + 2.2332 / 0.8 = 30.5764/1
24.461 = 391.436+24.2564U2 + 12.232
24.461 - 391.436 - 12.232 = 24.2564U2
U2 = (24.461 - 391.436 - 12.232 ) / 24.2564
U2 = 15.6
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jul1-12, 04:40 PM   #2
Admin
Don't ignore parentheses.
You already made a mistake in your first step. Where did you got 2.2332 from?
Jul1-12, 04:44 PM   #3
391.4368 + 24.264U2 / 0.8 + (15.290U2) = 30.5764
Now what will I do
and this next ..
Jul1-12, 05:01 PM   #4
Admin
Don't ignore parentheses. 391.4368 + 24.264U2 / 0.8 and (391.4368 + 24.264U2) / 0.8 are two different things.
Apart from lack of parentheses your first step looks OK now. But I still don't know where did you got 2.2332 from.
[tex]\frac{a+b}c = \frac a c + \frac b c[/tex]
Jul1-12, 05:04 PM   #5
391.4368 + 24.264U2 + (15.290U2) /0.8= 30.5764
now Is this step is correct ?
Jul1-12, 05:25 PM   #6
Admin
No, it is wrong. You can't move expressions at random, there are strict rules that you need to follow.
You are still ignoring parentheses, you are wasting your time and my time.
Jul1-12, 05:36 PM   #7
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Quote by Borek View Post
I think the 2.2332 is supposed to be 12.232, which is what you get by multiplying 15.290 by 0.8.
Jul1-12, 05:37 PM   #8
So now is my answer is correct or not ... ??
Jul1-12, 05:47 PM   #9
Recognitions:
It's kind of hard to follow what you did, so I'd have to say "probably not." First, take the sage Borek's advice and use parentheses. As he noted, a+b/c means something completely different from (a+b)/c. Don't make others guess what you mean when you can write it in a way that's perfectly clear.
So you're starting off with
30.581((12.8+0.8u2)/0.8) + 15.290u2 = 30.5764.
Now show us one step at a time what you're doing. It might help if you explained in words that you're doing each step as well.
Jul1-12, 06:13 PM   #10
Now I will multiply 30.581 X ((12.8+0.8u2) / 0.8
= 91.4368 + 24.4648U2 /0.8 + 15.290u2 = 30.5764.
now I will bring 91.4368 other side
24.4648U2 /0.8 + 15.290u2 = 30.5764 - 91.4368
24.4648U2 /0.8 + 15.290u2 = -60.8604
now I will apply this rule a+b/c to left side
24.4648U2 + 15.290u2 /0.8 = -60.8604
Now
-60.8604 (0.8) = 24.4648U2 + 15.290u2
u2 = -9.6
Note : U2 the 2 is not square
Jul1-12, 06:28 PM   #11
Recognitions:
Quote by manal950 View Post
How did you get
$$91.4368 + \frac{24.4648u_2}{0.8} + 15.290u_2 = 30.5764?$$
Jul2-12, 02:36 AM   #12
Admin
I think I know what is going on. You don't ignore parentheses - you have no idea they are necessary. You are consistently making the same error, which suggests you think (1+2)/3=1+2/3. That's incorrect. (1+2)/3=1/3+2/3. Each expression from the sum in the numerator must be divided separately.
New Reply
Thread Tools
Similar Threads for: How I can find U2 here ..
Thread Forum Replies
In each case find the shortest distance from the point P to the line, and find the po Precalculus Mathematics Homework 3
Find matrix for total angular momentum along y; find eigenvalues and eigenvectors. Advanced Physics Homework 0
Find the upper and lower boundary curve to find the area between two curves. Calculus & Beyond Homework 2
Shell method to find volumes: need to find intersections of the curves involved? Calculus 0
Find Find the point in this plane where it intersects the z axis Calculus & Beyond Homework 3
