Circuit Resonance: Understanding Natural Frequency
  • Context: Undergrad
  • Thread starter Thread starter thunderhadron
    Circuit Resonance
The discussion centers around the concept of natural frequency in electrical circuits, particularly in relation to resonance in LC circuits. Participants explore the definitions and differences between natural frequency and resonant frequency, as well as the implications of damping on these frequencies. The scope includes theoretical explanations and clarifications regarding oscillation behavior in circuits.
  • Some participants propose that the natural frequency is the frequency at which a circuit would oscillate without an external driving force, while the resonant frequency is the frequency at which the circuit responds with maximum amplitude to an applied e.m.f.
  • Others argue that the driving frequency at resonance is not the same as the natural frequency, though it is very close, and that the distinction becomes significant with varying levels of damping.
  • A participant explains that in a series LC circuit, energy oscillates between the inductor and capacitor most efficiently at the natural frequency, where total impedance is minimized.
  • There is a discussion about the difference between damped and undamped natural frequencies, with some participants noting that higher damping leads to a decrease in oscillation frequency.
  • One participant questions whether an LC oscillator has only one natural frequency or multiple frequencies at which current can reach a maximum, leading to further exploration of the topic.
  • Another participant clarifies that for a single LC oscillator, there is typically only one natural frequency, while more complex circuits may exhibit different behaviors.
Participants express varying interpretations of the relationship between natural frequency and resonant frequency, with no consensus reached on the definitions or implications of damping. The discussion remains unresolved regarding the number of natural frequencies in LC oscillators versus more complex circuits.
Participants highlight the importance of damping in defining natural and resonant frequencies, noting that real systems always exhibit some level of damping, which complicates the relationship between these frequencies. The discussion also touches on the implications of circuit design on resonance behavior.
thunderhadron
When the frequency of the applied e.m.f. equals the natural frequency of the electrical circuit the current reaches the maximum value and the circuit is said to be in resonance with the in resonance with applied e.m.f.
I am confuse with the natural frequency of the electrical circuit. What is this mean?
Thank you all in advance.
The driving frequency at resonance is not the same as the natural frequency - though it is very close to it. The natural frequency is the frequency at which the circuit would oscillate without an oscillating source driving it.
Inductors and capacitors are energy storage devices. If you have a circuit comprising an Inductor and capacitor in series then it's possible for energy to flow back and forth between the capacitor and inductor. It does this most easily at the natural frequency because at the natural frequency the total impedance of the circuit is at a minimium. Therefore at this frequency the losses in the circuit are at a minimium.
You probably know that the impedance of an inductor and a capacitor varies with frequency. For an inductor the impedance increases with frequency. For a capacitor it reduces with frequency. At some frequency the sum of the two impedances is a minium. That's the natural frequency at which the circuit will prefer to resonate.
See also
http://en.wikipedia.org/wiki/RLC_circuit#Natural_frequency
hi thunderhadron! :smile:
are you asking, i] what is the resonant frequency,
or are you asking, ii] what is the difference between the resonant frequency and the natural frequency?​
i] as you know, the impedance of the circuit is different at different frequencies,
and the resonant frequency is the one at which the impedance is real (no reactance)
ii] uart :smile: has explained it here …
uart said:
The presenter was most likely referring to the damped natural frequency versus the undamped natural frequency. When the damping factor is small the two are very similar, but as the damping is increased the oscillation frequency decreases.
For example in a parallel LRC circuit the undamped natural frequency is :
[tex]\frac{1}{\sqrt{LC}}[/tex]
whereas the actual oscillation frequency of the natural response's damped sinusoid is :
[tex]\sqrt{\frac1{LC} - \frac{1}{(2RC)^2}}[/tex]
Stonebridge said:
Resonance is a condition in which a vibrating system responds with maximum amplitude to a periodic driving force.
Mechanical systems (beams, pendula, springs, wine glasses, guitar strings etc) will have a number of possible frequencies at which this occurs. These are the system's natural frequencies of vibration. For example, a guitar string will have a series of possible frequencies where this happens, the lowest is called the fundamental frequency. The other frequencies are at values which are whole number multiples of the fundamental.
When resonance occurs, the frequency is often called a resonant frequency. This is just saying that resonance occurs when the driving force has the same value as one of the natural frequencies.
A beam can have more than one natural frequency, and therefore can be made to resonate at more than one frequency.
An (LC) series electrical circuit will resonate at a frequency given by f= (1/2π)√LC
This could be called its natural frequency or its resonant frequency. It doesn't really matter. (It's usually called its resonant frequency.)
uart said:
The characteristic equation for a second order system is of the form :
[tex]s^2 + 2 \alpha s + w_0^2[/tex]
For example in a parallel LRC circuit this would correspond to a function of the form :
[tex]s^2 + \frac{1}{RC} s + \frac{1}{LC}[/tex]
If the damping factor (alpha) is zero then the roots are at
[tex]\pm j \sqrt{1/(LC)}[/tex]
and it follows that the natural response is an undamped sinusoid of frequency 1/sqrt(LC).
When alpha is non zero the roots of the (quadratic) characteristic equation are
[tex]-\alpha \pm j \sqrt{(w_0^2 - \alpha^2)}[/tex]
from which it follows that the natural response is a damped sinusoid of frequency [itex]\sqrt{(w_0^2 - \alpha^2)}[/itex].
What do you mean by this? That confuses me. I almost want to disagree with you, but there could be something I'm confused about or I might not understand what you mean.
The first statement is a bit confusing. Let's try a longer version.
The frequency of the (damped) oscillations of a system with no exterrnal forcing depends on the amount of damping. "Natural frequency" usually means the theoretical frequency with zero damping, even though no real systems have zero damping. The change in frequency is very small if the damping is low. The relative frequency change is ##\sqrt{1 - \beta^2}## where ##\beta## is the damping factor, so even if ##\beta = 0.2## the change in frequency is only about 2%. But for high damping levels approaching critical damping the frequency change is NOT small, and if the damping is higher than critical (##\beta > 1##) there are no "oscillations" at all unless there is an external force.
There is also an issue about what you really mean by "at resonance". You can define that as the frequency when the applied force is exactly 90 degrees out of phase with the response. Or you can define it as the frequency where the response is a maximum, for a constant level of force input. The two are not necessarily the same.
For oscillating systems with small amounts of damping, none of this is very important in practice, so people often write as if "natural frequency" = "resonant frequency", rather than being precise about what they mean.
tiny-tim said:
:smile:
Mechanical systems (beams, pendula, springs, wine glasses, guitar strings etc) will have a number of possible frequencies at which this occurs. These are the system's natural frequencies of vibration. For example, a guitar string will have a series of possible frequencies where this happens, the lowest is called the fundamental frequency. The other frequencies are at values which are whole number multiples of the fundamental./QUOTE]
Hi Tim
Well now I am understanding this. As you talk about the string vibration it has ample number of natural frequencies at which it gives maximum sound. Same happens with the air pipes also like the vessels. If if we talk about an LC oscillator there we can find only one value of natural frequency. Is there only one value for which the current in the circuit becomes maximum or there can be a series of the frequencies?
Thanks @AlephZero. I should have said that the resonant frequency is not usually the same as the natural frequency of the circuit.
thunderhadron said:
… if we talk about an LC oscillator there we can find only one value of natural frequency. Is there only one value for which the current in the circuit becomes maximum or there can be a series of the frequencies?
for one LC oscillator, only one frequency (you can check that easily by solving the equations)
(for a complicated circuit with several oscillators, i don't know :redface:)
A well designed oscillator circuit will ensure that the basic LC components (or crystal) have high Q, intrinsically) and that the 'coupling' between the resonator and the amplifier / feedback part is very loose. This ensures that the oscillator is affected as little as possible by other influences.
Mechanical clock mechanisms have the same requirement, with the pendulum / balance wheel being as isolated as possible from the source of energy (spring / weights) and the losses in the oscillating bit kept to a minimum (jeweled bearings / pallets etc). A good clock will keep going for many cycles if you remove the drive to it.
When crystals are used in a circuit, they may be driven at overtone frequencies and not at their fundamental - but the oscillation of a bar of quartz is not equivalent to a simple LC combination.
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 27 ·
  • · Replies 24 ·
  • · Replies 30 ·
