New Reply
How many VDC will 120VAC support?
Share Thread Thread Tools
Jul6-12, 10:41 AM   #1
I am looking to install 6 48VDC power supplies and I am curious as to whether or not I can operate all 6 power supplies off the same 120VAC source. I am not sure if 120VAC means that I can only operate a max of 120VDC.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Jul6-12, 10:44 AM   #2
It depends on the current rating of your 120V sockets as well as the fuse. If your 6 48VDC power supplies draws current anywhere near to these ratings, then you are going to have fire safety issues.
Jul6-12, 10:57 AM   #3
Alright, thanks.
New Reply
Tags
alternating current, direct current, voltage
Thread Tools
Similar Threads for: How many VDC will 120VAC support?
Thread Forum Replies
1500w 120vac variable power control Electrical Engineering 3
Voltage amplifier (15mV signal on 120VAC offset) for shunt resistor/current sensing Electrical Engineering 6
"any superset of a support is also a support" Calculus 4
i need some help wiring 100 leds using 120vac Electrical Engineering 1
Car Battery and 120vac 100 watt bulb Electrical Engineering 9
