I can't do derivative of:(1025t^2-800t+400)^(1/2)
  • Thread starter Thread starter thomasrules
    Derivative
The discussion revolves around finding the derivative of the function (1025t^2-800t+400)^(1/2), which is related to calculus, specifically the application of the chain rule in differentiation.
  • Participants discuss the application of the chain rule and express confusion regarding the differentiation process. There are attempts to clarify the steps involved in differentiating the function, and some participants question the implications of setting the derivative to zero for finding maximum or minimum values.
Several participants have provided guidance on using the chain rule, while others express frustration with the complexity of the problem. There is an ongoing exploration of how to interpret the results of the derivative, particularly in relation to optimization in economics and science.
Participants mention the difficulty of the topic within the context of optimization and express concerns about understanding the material before progressing further in their studies.
thomasrules
Do you know the chain rule??If so,apply it.
Daniel.
use chain rule...
the derivative of x^1/2 = 1/2 x^-1/2
chain rule and above formulas should solve your problem... if you have no idea how to apply chain rule, look it up in your textbook and study carefully, you must fully understand before you goto the next chapter, otherwise, you will have a tough time in the future.
thanks you :)
ya I am doing Optimization in Economics and Science...SO DAMN HARD
so I end up getting f1(x)=(1/2)(1025t^2-800t+400)^(-1/2)(2050t-800)
THen my teacher jumps too: If f1(x)=0 2050t=800
WTF?
I asusme you want to differentiate with respect to t.
Let:
[tex]u=1025t^2-800t+400[/tex]
Then your function is:
[tex]u^{\frac{1}{2}}[/tex]
By the chain rule:
[tex]\frac{d \left( u^{\frac{1}{2}} \right)}{dt} = \frac{1}{2} \frac{du}{dt} u^{- \frac{1}{2}}[/tex]
You should be able to take it from there.
thanks you :)
WTF?
thomasrules said:
thanks you :)
WTF?
He/she is finding turning points?
trying to find t, sets 0 to find max or min
Not really,u should compute the second derivative as well.It's the only way you can decide which is max and which is min,if any...
Daniel.
  • · Replies 16 ·
