Why is the range of gravity considered infinite?
  • Context: Undergrad
  • Thread starter Thread starter AustinJones
    Gravity
The discussion revolves around the concept of the infinite range of gravitational fields in physics. Participants explore theoretical implications, personal interpretations, and the relationship between classical gravity and General Relativity, as well as the challenges of understanding gravity at large distances.
  • Some participants express confusion about the concept of infinite gravitational range and seek clarification on what "infinite" means in this context.
  • One participant notes that in classical gravity, gravitational field lines extend to infinity, suggesting this is a consequence of how gravity is modeled in both classical and relativistic frameworks.
  • Another participant shares a personal discomfort with the idea of infinite range, suggesting that there may be underlying principles or simple explanations that are overlooked in current theories.
  • Some participants argue that while General Relativity provides strong predictions, there is still uncertainty about its ultimate validity and whether it might be an approximation of a more complex theory.
  • Concerns are raised about the need for alternative theories to make distinct, testable predictions if they challenge the established understanding of gravity.
  • One participant emphasizes that observations have led to the development of theories suggesting gravity never truly reaches zero, even at vast distances, and discusses the implications of gravitational effects over large scales, such as those observed in galaxy clusters.
Participants express a mix of agreement and disagreement regarding the nature of gravitational range. While some accept the concept of infinite range as a modern physics perspective, others express skepticism and highlight the need for further understanding or alternative explanations.
Participants acknowledge the limitations of current theories and the dependence on observational data, noting that the assumptions underlying the infinite range of gravity may not be fully resolved.
AustinJones
please if your going to answer my questions with a formula explain it not just
something = z+r2
F=ma, true but i understand it better explained like; force equals the measured mass of an object multiplied by its rate of acceleration.
anyways, why are gravitational fields infinite?
How do we know they are infinite?
Infinite in what way?
I'm going to assume you mean infinite range. In classical gravity, gravitational field line can only start or terminate on a mass. So gravitational field will always extend out to infinity. This works because classical gravity is a low-energy approximation to General Relativity. And we don't really know why General Relativity holds. It's either just how the world works, or it's an approximation to an even more complex theory. But then we wouldn't know why the later holds either.
Anyways, we can't test this directly, of course. We cannot measure gravity from an object that's on the far side of the universe from here. But we can test whether the theory itself holds, and then we make an assumption that it holds at any range.
Yes, the range of the gravitational field is by modern physics considered infinite.
I'm not saying its wrong I'm just saying i personally without a education in physics, don't like that concept.
Over time we have developed a lot of things to try and understand gravity
a gravitational constant, a pattern gravity fallows 1/r^2, theories like gravitons.
I feel like were missing something very simple which makes our calculations wrong in the big end results.
While it's possible that long-range interaction somehow behaves differently, we have no good indication of that. On the contrary, we have very strong indication that General Relativity works. It gives extremely accurate predictions for certain phenomena. I don't want to discourage anyone from looking for alternative explanations, but they would need to make testable predictions that are distinct from GR, as well as explain why tested predictions of GR work so well.
Anything we know can be wrong. In fact, it's probably wrong. But ultimately, what we care about are predictions. If a theory makes predictions that work, we like that theory, and we are going to treat it as "this is how things work," even in situations where we know otherwise.
It isn't that we KNOW the range is infinite, it is that our observations have given us the means to develop theories and models that describe how gravity behaves. These models and theories tell us that the force of gravity falls off at a certain rate but never reaches zero. In the end I don't really see a big difference between being infinite and having a finite range. A finite range would certainly be so far away that it just doesn't matter. Consider that the center of the Virgo Galaxy Cluster is approximately 54 million light years away yet it's gravity affects our own galaxy and slows our recession down. So the range is already greater than 54 Mly, as part of the cluster is beyond that distance. Given the nature of cosmological models that describe the evolution of the universe over time it may matter if the range is significantly less than the diameter of the observable universe, but that's about the only thing I can think of where it would really matter.
  • · Replies 51 ·
  • · Replies 69 ·
  • · Replies 51 ·
  • · Replies 18 ·
