What is the Range of 4/sqrt(5-2x) and How Can It Be Determined?
  • Thread starter Thread starter viendong
    Range
The discussion revolves around determining the range of the function 4/sqrt(5-2x). Participants are exploring the implications of the function's definition and the conditions under which it is valid.
  • Participants discuss the necessity of ensuring the expression under the square root remains positive, which leads to questions about the domain and its relation to the range. There are attempts to graph the function and interpret the results, alongside discussions about isolating variables and inverting the function.
There is a mix of interpretations regarding the range, with some participants suggesting it is between 0 and 7 based on graphical analysis, while others emphasize the need to consider the function's behavior and restrictions on y-values. Guidance has been offered on isolating x and understanding the implications of squaring both sides of the equation.
Participants note that the function is undefined for certain values, specifically when y equals 0, and that the original function must yield positive values. There is an ongoing exploration of the assumptions related to the function's behavior and the conditions for valid outputs.
viendong
I really need help how to find range for this question... thanks
4/sqrt(5-2x)
You cannot take the sqare root of a negative number (at least no without obtaining imaginary numbers...) So the range would correspond to when
(5-2x) is positive.
so, this is the answer... :shy: really confused. thanks
when I graphed in the calculator, it appeared that the range is between 0-7...
Actually, you must first isolate x in the equation. Then find for what values of y the function doesn't exist.
4/sqrt(5-2x) is defined only for 5-2x> 0 or x< 5/2. That's the domain, not the range. The range is the set all possible y values when y= 4/sqrt(5-2x). One way to determine that is to solve for x (invert the function) and then think about domain: y= 4/sqrt(5-2x) so y(sqrt(5-2x)= 4 and sqrt(5-2x)= 4/y. Now square both sides: 5-2x= 16/y2 so -2x= 1/y2 - 5 and x= -1/2y2 + 5/2. That's defined for all y except 0 (because y is in the denominator and we can't divide by 0) but we have to be care about that squaring. Looking back at the original function, y obviously must be positive (4 is positive and the square root is never negative). The range is all positive real numbers.
  • · Replies 21 ·
  • · Replies 21 ·
