| New Reply |
question on wiring fire wire to usb wire? |
Share Thread | Thread Tools |
| Jul9-12, 11:12 PM | #1 |
Can i wire fire wire to usb wire? What i mean is cut one end off on a fire wire and one end off a usb wire and wire the two together would that work?
| Jul9-12, 11:23 PM | #2 |
You mean using a Firewire cable for USB? Firewire is 110Ω differential impedance, USB is 90Ω. I would be careful if you run USB2. For USB 1, I don't think you'll have a problem. Secondly, you are going to have to change the two end connectors to fit for USB, that will cause reflection.
Go buy a cable, why do you want to monkey with RF stuff? If you try to connect a USB port to Firewire port..............You're funny!!! |
| Jul10-12, 12:11 AM | #3 |
Recognitions:
You can get cheap adaptors to connect USB to Firewire, probably cheaper than buying the different plugs:
http://www.ebay.com.au/sch/i.html?_f...to+USB+adaptor |
| Jul10-12, 12:30 AM | #4 |
Why do people want to use adapter? Get a real USB or Firewire cable!!!!
| Jul10-12, 01:00 AM | #5 |
Recognitions:
I imagine he wants to use a firewire device and only has USB on a computer.
Haven't heard of firewire for years, though. Some video cameras used to use the Firewire system for outputting video. |
| Jul10-12, 03:03 AM | #6 |
Those adaptor are just switching connectors only. It takes a micro controller the interface FW to USB. |
| Jul10-12, 03:07 AM | #7 |
I have had to install a firewire card in my desktop to support my old video camera.
| Jul10-12, 03:29 AM | #8 |
I designed both, I don't like FW at all. The 110Ω differential pair make it harder on layout. Even though the two are only 20Ω difference, but the FW traces are much thinner and loss is much higher. Also you have to match the length of the two pairs on the FW. That's why you often see one pair of traces zip zagging to increase the length to match the other pair. TI was the main chip set maker, they never have embedded controller with FW interface. At the time Cypress dominated USB, they used 8051 core with USB interface. This make it a lot easy and simpler to implement a controller. The only one good thing I saw was the peer to peer of FW. You can do things with FW that you cannot do with USB because any FW module can talk to any other FW module on the bus. It is really like a true bus rather than like USB where everyone talk only to the master.
| New Reply |
| Thread Tools | |
Similar Threads for: question on wiring fire wire to usb wire?
| DIY headphone wiring (nylon-stranded wire) | Electrical Engineering | 2 | ||
| path of least resistence, static wire in B field or moveable wire? | Electrical Engineering | 1 | ||
| Wire Loops, Current, Magnetic Field, & Straight Wire HELP! | Introductory Physics Homework | 1 | ||
| 0.5V across 1.5m tungsten wire w/cross-sect. area 0.6 mm^2 - Find wire current | Introductory Physics Homework | 3 | ||
| Wiring question: Going from larger wire to smaller wire | Electrical Engineering | 11 | ||
