Calculate Percentage Purity by Mass of C10H7OH Contaminated with LiBr
  • Thread starter Thread starter physicsss
    Urgent
The discussion focuses on calculating the percentage purity by mass of a C10H7OH sample contaminated with LiBr. The combustion analysis revealed 77.48% carbon and 5.20% hydrogen, leading to the conclusion that the remaining mass percentage is attributed to oxygen and LiBr. To determine the percentage purity, one must subtract the mass of LiBr from the total sample mass, with the formula indicating that the remaining elements can be calculated based on the known composition of C10H7OH.
  • Chemical composition analysis
  • Understanding of combustion analysis
  • Basic knowledge of percentage calculations
  • Familiarity with molecular formulas and mass percentages
  • Study the principles of combustion analysis in organic compounds
  • Learn how to calculate mass percentages from empirical formulas
  • Explore the properties and effects of LiBr as a contaminant
  • Investigate methods for purifying organic compounds
Chemistry students, analytical chemists, and professionals involved in quality control of chemical substances will benefit from this discussion.
physicsss
A sample of C10H7OH was found to be contaminated with a small amount of LiBr. The combustion analysis of the sample gave the following results: 77.48% C and 5.20% H. Assume that the only species present are C10H7OH and LiBr, calculate the percentage purity by mass of the sample.
First of all, what is the percentage of purity by mass...? And second, does it mean that 100%-77.48%-5.20% gives the percentage of O and LiBr?
Chemistry news on Phys.org
If you had 100g of the sample and found that it contained x grams of LiBr, then the percentage purity would be 100-x.
From the formula of the compound, can you not determine how much O there is in it ?
  • · Replies 19 ·
11K
9K
