New Reply
temperature and the equilibrium constant
Share Thread
Jul12-12, 08:32 PM   #1
The equilibrium constant changes with a change in temperature, I am confused as to the directions and why Qc is behaving oppositely of what I think it does
For example, my textbook says a temperature increase favors an endothermic reaction (left to right) and a temperature decrease favors the exothermic direction (from right to left). This is ambiguous to me, I am not sure what they mean by favor, if somone can clarify.
Anyway, here is an endothermic reaction
heat + A ⇔ B + C
If you increase the temperature, the heat is treated as a reactant and it shifts from left to right, that is fine
Exothermic:
A + B ⇔ C + heat
decrease the temperature, shouldnt this shift from left to right, since the heat is treated like a concentration and it is taken away, so to make up for it more is going from left to right, yet the book says right to left.
My other concern is how the equilibrium constant changes with temperature. We had a worksheet and its says heating an endothermic equilibrium system increases K. The answer given is true, and I have 2 thoughts on this.
The first is that if you have an endothermic reaction, heating it up increases the number of the reactant side, so the denominator is bigger and K is lower. However, if you increase the temperature, equilibrium would shift to the right so now the numerator is bigger, and therefore K is bigger. I think the second statement is the correct one, but just want to confirm.
It says cooling an exothermic equilibrium increases K. That mens equilibrium shifts to the right (which contradicts my textbook from above) and the numerator is now bigger, so K is bigger.
PhysOrg.com chemistry news on PhysOrg.com
>> New microfluidic chip can help identify unwanted particles in water and food
>> Unexpected behavior of well-known catalysts
>> Study finds chemical behind cancer resistance in naked mole rats
Jul13-12, 11:17 AM   #2
Quote by Woopydalan View Post
Exothermic:
A + B ⇔ C + heat
No, it should be favoring the products (shifting right to left). Heat is not exactly the same thing as temperature. If temperature is decreased, heat is leaving the system. The system will "maintain" its temperature by reacting to the product side to release heat.
Right ----> Left
Le Chatelier's principle.
Jul13-12, 12:51 PM   #3
Maybe we're reading this different, but if its favoring the products, you are saying some of the reactants are going to go to the product side. The reactants are on the left, and the products are on the right. Therefore, reactants (left) to products (right)?
Right -----> Left is backwards, my right hand is on the side where you have written left
Left -----> Right should be how you wrote it, no?
Jul13-12, 04:03 PM   #4
Hahah I just realized that I did write it incorrectly. I apologize.
Products are definitely favored in an exothermic reaction when temperature is decreased.
New Reply
Similar discussions for: temperature and the equilibrium constant
Thread Forum Replies
Body whose temperature is constant but not the same all over. Thermal equilibrium? Classical Physics 2
equilibrium constant and rate constant Materials & Chemical Engineering 6
equilibrium constant varying with temperature...but confused! Biology, Chemistry & Other Homework 3
Effect of raising temperature on equilibrium constant? Biology, Chemistry & Other Homework 1
