Solving Non-Homogeneous Poisson Equation: Techniques and Practice Problems
  • Context: Graduate
  • Thread starter Thread starter ericm1234
    Poisson
The discussion centers around solving a non-homogeneous Poisson equation in polar coordinates, specifically the equation Δu = -1 with boundary conditions u(1, θ) = sin(θ) and u finite at r = 0. Participants explore various techniques and approaches to find a solution, including eigenfunction expansions and trial solutions.
  • Homework-related
  • One participant suggests breaking the solution into u = u1 + u2, where u1 solves Laplace's equation and u2 addresses the non-homogeneous part.
  • Another participant proposes using eigenfunctions to solve for u1 and suggests that u2 should satisfy Δu2 = -1 with u2 = 0 at r = 1.
  • Concerns are raised about the lack of clear examples in textbooks for similar non-homogeneous Poisson problems in circular domains.
  • One participant mentions the importance of circular symmetry in determining the form of u2 and suggests a trial solution of the form u2 = Ar^n.
  • There is a discussion about dropping terms in the polar Laplacian when boundary conditions do not depend on θ, with clarification that boundary conditions refer to conditions at r = 1.
  • Participants express uncertainty about the reasoning behind choosing specific forms for solutions and the implications of boundary conditions on the solution structure.
Participants generally agree on the approach of separating the solution into u1 and u2 and the use of eigenfunctions. However, there is no consensus on the specific methods for solving u2 or the interpretation of boundary conditions, indicating multiple competing views and unresolved aspects of the discussion.
Participants note limitations in available resources and examples for practice, highlighting a potential gap in instructional materials for non-homogeneous Poisson equations in polar coordinates.
ericm1234
Solve:
Δu=-1, u(1, theta)=sin(theta). 0<r<1, -pie<theta<pie, u finite at r=0
What I've done: u=u1+u2. Δu2=0, with u(1, theta)=sin(theta). So eventually u2=rsin(theta).
The u1 problem however I am not sure how to solve. Eigenfunction expansion doesn't seem like it would work (though not exactly sure why, if so).
Help?
Let u = u1 + u2, where u1 solves Laplaces equation with the boundary condition you've given (hint: use eigenfunctions). Then let u2 be any function such that Δu2 = -1 and u2 = 0 on the boundary (i.e. at r=1)
As I said, not sure how to solve the non-homogeneous part u2=-1
Also as I said this is a circular problem; you can tell me generalities but I don't see how they'll help. I can find no single relevant example of this in my textbook or ANYWHERE online, involving a nonhomogeneous poisson problem in this circular situation. Yet my upcoming masters exam practice tests have an abundant number of these with terribly written solutions.
In certain situations, though I have no idea how to tell when, it seems "circularly symmetic" comes into play, thus leading to the disregarding of the 3rd term in the polar laplacian.
Fair enough, I'm happy to go through this:
Firstly, I'm assuming you're fine with u1? Just look at the general solution to Laplace's Equation in plane polars and pick the eigenfunctions which are proportional to sin(theta) whilst eliminating the one which is singular at the origin. Then to work out your constant just plug in r=1 and you're done.
As for u2, well, you have: Δu2 = -1, u2 = 0 at r = 1 and u2 finite at the origin.
From the boundary conditions, you can tell that this is going to be circularly symmetric (otherwise one of your boundary conditions would depend on theta).
Now, write out Δu2 in plane polars but exclude the last term as u2 does not depend on theta. Then try a solution of the form u2 = Ar^n and you should find that for Δu2 = -1, n = 2 and A = -1/4. Now your last problem is that you just need to satisfy u2 = 0 on the boundary so you can just add in an appropriate constant (as Δ acting on a constant will be zero) and as I'm sure is quite obvious, plug in r=1 and the constant you want is going to be 1/4. Thus you have u2 = 1/4 (1 - r^2) and you can add this to u1 to get your solution :)
[Note: I may have made a mistake whilst typing that, I was just doing it off the top of my head as opposed to writing it down and then copying it out, but I hope you get the idea!]
JJacquelin said:
Hi !
The boundary conditions imply to express the result on the form of a Fourier series.
Ahhhhhhhhhhhhh, sorry I may have completely forgotten everything I learned in second year undergrad, but I'm almost certain that the solution is going to simply be:
u = rsin(theta) + 1/4 (1 - r^2)
Obviously you are rigth. Your solution is the right one and the simplest one.
Moreover, there was a mistake in my complicated developments. So, I delete my previous post.
Haha, thanks, I was worried I'd forgotten how to do these for sec!
Ok, if I may ask, what was your reasoning for choosing a soln of the form Ar^n?
Do we always drop the last part of the polar laplacian if the boundary conditions don't depend on theta? By boundary conditions, do we just mean the condition at r=1?
Right, u2 is just a particular solution so frankly any function that satisfies Δu2 = -1 with u2 = 0 at r=1 will do. This is usually just a case of trial and error but because maths is (almost) always really nice, you'll find that often some reasonable function will always work (e.g. a polynomial, trig function or exponential). In this case, we knew we wanted Δu2 = -1 so the RHS is a constant and we know that it's possible for me to get a constant on the LHS if we use a function of the form Ar^n (and it just so happens n=2)
Boundary Conditions are exactly what they say on the tin, it's the information you've been given on the boundary of your problem. In this case your solution lies in the circle of radius 1 and your boundary is at r=1.
For u1, the boundary condition was u = sin(theta) at r=1 so you have an eigenfunction forcing on the boundary and hence u is proportional to that particular eigenfunction i.e. [ar + b/r]sin(theta). You then impose u finite at the origin so b=0 and you work out what a is by plugging in r=1 (so obviously a=1 by your boundary condition)
For u2, the boundary condition was u = 0 at r=1 and as this doesn't depend on theta, you know that u2 is going to be independent of theta (thus the last term in the plane polar laplacian drops out).
Basically, Boundary conditions determine what your solution is going to look like. You could write out the full eigenfunction expansion if you wanted but you'll find that all the coefficients of the ones that aren't in your boundary condition will vanish.
Hope that helps :)
Thanks Mario.
Any chance of you knowing where I can find similar examples like this to do?
Not sure where you could find practice material. I found these kinds of problems cropped up a lot in my second year of undergrad in a mathematical methods course as well as a course on electromagnetism and a course on fluid dynamics.
Feel free to have a look at the exam papers I did, however the questions aren't particularly straight forward and may end up not being of much help at all:
http://maths.cam.ac.uk/undergrad/pastpapers/
(you want to look at the IB papers and look at questions from Methods, Electromagnetism and Fluid Dynamics)
  • · Replies 36 ·
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 16 ·
