New Reply
introductory rotational dynamics/energy conservation question
Share Thread Thread Tools
Jul15-12, 10:34 AM   #1
Hey guy's im kind of struggling with this i would appreciate any help
A potter's wheel having a radius 0.49 m and a moment of inertia of 12.1 kg · m2 is rotating freely at 52 rev/min. The potter can stop the wheel in 6.0 s by pressing a wet rag against the rim and exerting a radially inward force of 74 N. Find the effective coefficient of kinetic friction between the wheel and the wet rag.
2. Relevant equations
kinematics
Wnc = ΔRotational Energy
3. The attempt at a solution
Ok here so i started this one trying to do an energy conservation 74Δx(or θ) + uknΔx = (1/2)iω^2
To represent the non conservative forces on one side and the change in rotational kinetic energy on the other, Δx being the stopping distance that can be obtained from kinematics
then i figured there might be a radial component instead of a torque
ƩFr = n + 74 = v^2/r*m
so the radial component gives u an n i can sub back in the conservation equation and it points in the same direction, is this anywhere near right or should i be representing the forces over a torque
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Jul15-12, 10:39 AM   #2
Mentor
You can figure out what the stopping torque was using the info given.
You can figure out what kind of *tangential* force would have to act to provide this torque.
The coeff of friction relates this tangential force to the radial force (which is normal to the surface).
Jul15-12, 10:39 AM   #3
Mentor
What force is exerting the torque on the wheel?
Jul15-12, 12:36 PM   #4
so i guess i would be assuming acceleration is constant get it from α then
(.49)74-.49(Ffric)=Iα
are the radial force and the friction both part of the x dimension? they just get separate equations so
-ukn = ma and n = (v^2)/(r)*m-74
Jul15-12, 12:45 PM   #5
Mentor
Quote by kinslow31 View Post
Only the tangential force exerts a torque.
New Reply
Thread Tools
Similar Threads for: introductory rotational dynamics/energy conservation question
Thread Forum Replies
Conservation of Rotational Energy Question Introductory Physics Homework 1
Rotational Energy Conservation Introductory Physics Homework 2
Conservation of energy in rotational motion Introductory Physics Homework 5
Rotational Energy conservation Introductory Physics Homework 4
Conservation of rotational energy Introductory Physics Homework 1
