What are the shapes of atomic orbitals
The discussion revolves around the shapes of atomic orbitals, specifically the s, p, d, and f orbitals. Participants explore the reasons behind these shapes, the concept of nodes, and how the shapes can be derived from wavefunctions. The conversation includes theoretical explanations and challenges regarding the understanding of orbital shapes.
  • Some participants assert that the shapes of orbitals are determined by nodes, which are regions where the probability of finding an electron is zero.
  • One participant explains that for s orbitals, the absence of angular momentum leads to spherical symmetry, while p and d orbitals have more complex shapes due to their angular momentum.
  • Another participant introduces the idea of complex orbitals with specific angular momentum components, suggesting that these may explain the doughnut shape of certain d orbitals.
  • There is a discussion about how to visualize these shapes, with some participants emphasizing the need to solve the Schrödinger equation to derive the wavefunctions that describe the orbitals.
  • Some participants express confusion regarding the communication of ideas, particularly about whether the focus should be on plotting the wavefunctions or understanding their derivation.
Participants generally agree that the shapes of orbitals are related to nodes and wavefunctions, but there is disagreement on the clarity of communication regarding how these shapes are derived and visualized. Multiple competing views on the interpretation of orbital shapes and the methods of understanding them remain unresolved.
Some participants note that the discussion may involve assumptions about the audience's prior knowledge of quantum mechanics and the mathematical treatment of wavefunctions. There is also mention of the complexity involved in visualizing higher-dimensional shapes.
shivamdabas
I know that the shape of s orbital is sphere, p orbital is dumbbell shaped and d orbital is like a doughnut but why do these orbitals have these shapes why not some other shape.
welcome to pf!
hi shivamdabas! welcome to pf! :smile:
i think the easiest way to understand the shapes is to consider the nodes
the nodes are where the probability is zero … so the individual shapes have to fit between them! :wink:
the nodes are planes, spheres, and/or a cone
for s, (and for n ≥ 2) all the nodes are (concentric) sphere(s), so the shapes that fit between them must be spheres or spherical shells
for p, the nodes are one plane and (for n ≥ 3) sphere(s), so the shapes that fit are blobs on either side of the plane, and smaller blobs to fit inside the sphere(s)
for d, the nodes are two planes or a cone and (for n ≥ 4) sphere(s), so the shapes that fit are blobs in the four regions between the planes, or two blobs "inside" each half-cone and one donut fitting "round" the cone, and smaller blobs to fit inside the sphere(s)
for f, I'm not sure where the nodes are
what about 1s ? :rolleyes: it has no nodes, sooo …
i say, i say, i say, my 1s orbital has no nodes
your 1s orbital has no nodes? how does it shell?
spherical! :biggrin:
Thanks for you reply
Now, I know that the shapes of the orbitals are governed by nodes which are the places where probability of finding an electron is zero but how can we know about the shape of these orbitals.
i think it's …
the number of spherical nodes is n-l-1, and the number of plane nodes is l (or l-2 plus a cone node)​
Think of the total wavefunction as the product of an angular wavefunction and a radial wavefunction.
For s orbitals, there is no angular momentum, and therefore the orbitals will have spherical symmetry. This means at r=0 the wavefunction can (and generally will) be nonzero.
For other orbital types, the angular momentum is nonzero, and the angular wavefunction will therefore have alternating regions of positive or negative value, separated by nodes. Of course, for the wavefunction (and its first few derivatives) to be continuous at r=0 the radial wavefunction must approach zero at r=0.
Each additional increment in angular momentum about the z axis adds a nodal plane containing the z axis.
Each increment in angular momentum perpendicular to the z axis will add a cone-shaped node with an axis parallel to the z axis. If there are an odd number of "cones", then one of them will actually be a plane containing the equator of the atom.
The node count mentioned only works for real orbitals. As the OP mentioned doughnut shaped d-orbitals, I think he talks about complex orbitals with definite z-component of angular momentum.
In these toroidal shaped orbitals the phase of the wavefunction changes, at least in the simplest cases, like exp(imf) where f is the angle in the x-y axis. The real orbitals are combinations of complex orbitals with +m and -m, hence they change like cos(mf) or sin(mf).
Er... let's get the obvious out of the way here because I think there's some miscommunications going on.
1. You solve the Schrödinger equation for, say, the hydrogen atom. You get the wavefunction.
2. In doing #1, you end up with two parts: the radial solution R(n,l), and the orbital solution P(l,theta).
3. If you plot the wavefunction, you get those shapes!
So to know where those shapes came from, you have to solve for the wavefunction. Check out this link:
http://panda.unm.edu/Courses/Finley/P262/Hydrogen/WaveFcns.html
I have no idea what you already know, or if this is what you are asking for. But practically everything here is derived from some First Principles starting point.
Zz.
I assumed he was referring specifically to d(z^2) orbitals, which are shaped like a doughnut and two teardrops.
Well, that's great if you can visualize four dimensions to plot it in, or visualize the probability density as the turbidity of a fog...
But the standard way to "plot" an orbital is to pick a cutoff value for the probability density such that the combined areas above the cutoff value have a volume that's 90% (as an example) likely to contain the electron. By analogy, using a similar method to plot the wavefunction for a particle in an infinite square well would look like a dashed line rather than a sine wave.
Who said anything about plotting?
I was reading the questions posted by the OP carefully, trying to decipher what was being asked! Here, look at them again! The bold emphasis are mine.
It appears that this person is asking for where in the world these things came from, and how do we know that they are what they are in the first place! It is NOT how to visualize these things, which is what most of the answers in this thread seem to be addressing.
I'm answering the question the way I think it is being asked.
Zz.
Since you asked:
I was just pointing out that the way you plot orbitals isn't the normal way you plot a function.
I'm not just being pedantic or trying to get the last word in...from my experience teaching, it's a non-trivial step for some people to follow.
PhaseShifter said:
Since you asked:
But plotting it, if you look at my response, isn't the answer, mainly because that isn't the question!
I was describing where and how those things are derived. You don't have to plot such things if you can visualize it in your head. Most of us can't, and that's why we plot it out to see what it looks like. But that isn't the essence to the answer.
Zz.
Great link and I want to understand this better, ZapperZ, so notationally speaking...
n, m, l are Principal, Magnetic and Azimuthal Quantum Numbers
a_0, I am assuming is the Bohr Radius.
e, in these equations, I am also assuming is Euler's number. (As opposed, for instance, to the elementary charge)
R_ml, Y_lm and r are what exactly?
TIA,
AC
Thanks everyone especially ZapperZ and PhaseShifter, if you can then please explain me what is radial wave function and angular wave function.
It would help, next time, that you say a bit about your level of knowledge. In this thread, I feel that we keep having to move backwards after each answer given. This is a prime example.
Separability is a mathematical "operation". You write a function F as factors of its components, i.e. F = X(x)Y(y)Z(z).
For the solution to the Schrödinger equation, one writes this as F = R(r)P(theta)L(phi), meaning the radial and orbital components are separated out.
See this:
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/hydsch.html
TIA,
AC
I think the link above may answer these questions as well. The Y_lm are the spherical harmonics.
Zz.
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 21 ·
