Lattice Points and Equilateral Triangles: A Proof
The discussion revolves around proving that a triangle with vertices at lattice points cannot be equilateral. Participants explore the properties of equilateral triangles, particularly focusing on the implications of irrational values associated with their angles and areas.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants examine the relationship between the sine of angles in equilateral triangles and the nature of lattice points. Some suggest that the irrationality of certain values may imply contradictions in the context of lattice points. Others propose alternative methods, including the use of Pick's theorem and vector geometry, to address the problem.
The discussion is active, with participants questioning the validity of initial proofs and suggesting further exploration of the properties of triangle areas. Some participants have provided hints and guidance on potential approaches, while others are still seeking clarity on the assumptions regarding areas of triangles with lattice points.
There is an ongoing debate about the rationality of areas for triangles with lattice points, with references to Pick's theorem and the implications of translating triangles in coordinate systems. Participants are also considering the implications of irrational values derived from trigonometric functions in the context of lattice points.
courtrigrad
Hello all
In a ordinary syatem of rectangular coordinates, the points for which both coordinates are integers are called lattice points . Prove that a triangle whose vertices are lattice points cannot be equilateral. Ok so I know that in a equilateral triangle the angle measures are [tex]\frac{\pi}{3}[/tex].Assuming that we do have an equilateral triangle then we know that [tex]\sin \frac{\pi}{3} = \frac{\sqrt{3}}{2}[/tex] which is irrational. Hence we cannot have lattice points.
Is this sufficient enough to qualify as a proof?
Thanks
courtrigrad said:
Hello all
Thanks
Nope. The isosceles right triangle formed by the points (0,0), (1,0), (0,1) has a hypotenuse of length [tex]\sqrt{2}[/tex]. :smile:
but that's a isoceles right triangle. I am talking about only an equilateral triangle. The definition of an equilateral triangle is that: all angles and all sides are equal
Thanks
Thanks
Your proof rested on the fact that the sine of one of the angles is irrational. I showed that this does not prove your statement since sines of angles of triangles exist that are irrational in the lattice, not that an equilateral triangle exists. In other words, you need to find another approach or further your statement into one about the sides of the triangle. :)
No. You've arrived at a key step, but you haven't finished the proof. You haven't even talked about the vertices of the triangle yet!
but you are only trying to prove it for only equilateral triangles .
Let's try a direct approach. What are you implying by the fact that the sine of pi/3 is irrational ?
Nothing in your argument distinguishes between equalateral, isosceles, or even scalene triangles. If it was valid, you would have disproven the existence of the triangle hypermorphism demonstrated. :-p
ok so because [tex]\frac{\sqrt{3}}{2}[/tex] is irrational, this implies that the distance from the vertex to the midpoint of the base is irrational. But this should be rational because of the laattice points?
Thanks
Nope. Consider hypermorphism's example!
I am not sure if this is correct but:
If we have an equilateral triangle of sides of length [tex]a[/tex] then the altitude is [tex]\sqrt{a^2 - (\frac{a}{2})^2} = a\sqrt{\frac{3}{2}}[/tex]. So the area is [tex]a^2\sqrt{\frac{3}{2}}[/tex] which is irrational. This is irrational area, but any triangle with lattice points has a rational area.
Is this correct?
PS: How would I use the irrationality of [tex]\sin \frac{\pi}{3} = \frac{\sqrt{3}}{2}[/tex] to prove this because my text (Courant) suggests it?
Thanks :smile:
I am not sure whether to assume that the area of a triangle with lattice points is rational.
No you can't. It's generally not true.
Try a proof by contradiction. Assume the triangle is equilateral with lattice points.
A couple of hints:
1) Translate the triangle so that one point is at the origin. If the original triangle had lattice points, then so does the translated triangle.
2) Write the coordinates of the translated triangle in polar form.
Actually, I think this one's right -- I think the area of a polygon whose vertices lie on a lattice is a rational function of the number of points lying on the polygon, and the number lying inside the polygon.
In any case, you could use vector geometry to prove the area of a triangle with vertices on the lattice must be rational. (which is how I would have done the problem)
And no, you should not assume it's rational, you have to prove it, or reference a theorem. :-p
Oops! Yes, you're right. Sorry about that!
You'll find Pick's theorem intriguing. :smile:
So I take it that If I use Pick's Theorem, then I have a formal proof? Also I would I convert the cartesian coordinates into polar coordinates?
Thanks :smile:
Thanks :smile:
If you're allowed to use Pick's theorem, then you should be fine. Like Hurkyl
said you can also use vector geometry to prove the area must be rational.
Don't worry about the polar coordinates. I was referring to a different way
to solve the problem, not related to the area of the triangle. I didn't realize that the area had to be rational.
I think the area method might be easier. But if you're interested I've described my idea below.
Translate to the origin, then write the cartesian coordinates of the triangle vertices like this:
[tex](0,0)[/tex]
[tex](Acos\alpha, Asin\alpha)[/tex]
[tex](Acos(\alpha+60),Asin(\alpha+60))[/tex]
A is length of the triangle.
If [tex]Acos\alpha[/tex] and [tex]Asin\alpha[/tex] are integers then using the cosine sum formula you can prove that [tex]Acos(\alpha+60)[/tex] is not an integer (proving the third point is not a lattice point leading to a contradiction). Or you can prove that [tex]Asin(\alpha+60)[/tex] (the y coordinate instead) is not an integer using the sine sum formula.
Pick, that's it! I couldn't remember its name.
With Pick's it's a beautiful and elegant proof.
Let one side of the triangle be [itex]l[/itex]. Now [itex]l^2[/itex] has to be integral because all the vertices lie on lattice points.
The area of the triangle is given by
[tex]\frac{1}{2}l^2\sin{\frac{\pi}{3}} = \frac{1}{2}l^2\frac{\sqrt{3}}{2}[/tex]
which is irrational. But the area is rational by Pick's theorem, and we have a contradiction. Hence no lattice point triangle can be equilateral.
10K
  • · Replies 0 ·
26K
