Uniform Magnetic Field's Effect on Moving Charges
The discussion revolves around the behavior of charged particles in a magnetic field, specifically focusing on charges 1 and 3, which have the same mass and speed. Participants are exploring how to determine the magnitude and sign of the charges based on their trajectories in a magnetic field, which is indicated to be directed into the screen.
  • Participants are attempting to interpret the significance of the arrows representing particle paths and their relation to the magnetic field. Questions are raised about how to deduce the charges' signs from the direction of motion and the field direction. There is also inquiry into the relationship between the radius of curvature of the paths and the forces acting on the charges.
The discussion is active, with participants providing insights and asking clarifying questions. Some guidance has been offered regarding the interpretation of the magnetic field and the application of the right-hand rule, although there is still confusion about the underlying concepts and how to apply them to determine charge signs and forces.
Participants are navigating the complexities of the problem, including the assumption that the magnetic field is uniform, while some suggest it may not be. There is also a focus on the implications of different trajectories for charges with the same mass and speed.
wolfpack11
Charges 1 and 3 in the figure below have the same mass and the same speed. Which has the greater magnitude of charge? What are the signs of the charges?
http://www.webassign.net/colfunphys1/21-p-001.gif
F = |q|v*B*sin(θ)
The x'es indicate that the direction of the magnetic field is into the screen. What are the arrows referring to? I think the solution has to do with what's perpendicular to the field, and the x-and y- components of these arrows. Can someone help interpret and explain? Thanks!
F = |q|v*B*sin(θ)
The arrows refer to the paths taken by the 3 particles. From the direction they bend, and from their radii, you can infer things about their mass and charge...
You titled this "Uniform Magnetic Field ..." but it looks to me like the whole point of this problem is that the field is NOT uniform- and that's why particles with the same charge and mass have different trajectories.
They don't have the same charge.
The arrows, as Berkeman said, show you the path that the charges move along as time progresses.
So, what causes an object to curve? Changing direction means a change in velocity, so an acceleration. You cannot accelerate without a force being applied, so where is the force in this case?
What can you tell us about Charge 2, since it did NOT curve?
Charge 1 curved to the left, and charge 3 curved to the right, the field is down. So from this you should be able to state which is positive and which is negative.
The last element is in which curve is a portion of a smaller radius circle. That would mean a stronger force applied. How do you get a stronger force applied from the same magnetic field?
Thanks for clearing it up a bit, xienwwolf. I don't know how to answer your questions though.
I'm still confused on how you can tell which charge is positive and which is negative based on their directions of motion and the field direction. Can someone explain the underlying concept/reason for this? My whack at an explanation is that the field/field lines are defined as moving from positive to negative (or vice-versa, from negative to positive), which would mean that positive and negative charges tend to move towards their opposite poles.
And why does a smaller radius of motion mean a stronger force applied? It seems that the magnetic force would be in the positive y- direction because it would then be perpendicular to both the field and the motion/velocity/displacement. From the equation though, it's evident that the uniform field produces stronger forces on larger charges.
Thanks a million!
Look in your book for something called the "right hand rule" and see if that clears up your confusion about direction/charge.
The field lines are defined by the "X" symbols. That means the field lines point into the screen/paper. Field lines are drawn from North to South outside of a magnet, so that means the North Pole is where your eyes are, and the South Pole is on the other side of the screen/paper.
You are correct in saying that the force should be perpendicular to both the field and motion. But you are incorrect in saying that the force would always be in one direction.
Right where the charges are drawn (initial velocity), in which direction are they moving (instantaneous velocity)? At the end of the arrows, in which direction are they now moving?
As for questions you do not know how to answer: The best approach is to type out what your thoughts are when you attempt to answer the questions. That allows us to see your reasoning and fill in the gaps, or help you make a small connection to continue moving along the line of reasoning. Each of my questions are designed to help you pick up a vital piece of information for answering the problem. So any question you cannot answer indicates a reason for why you cannot finish the original problem.
  • · Replies 19 ·
  • · Replies 31 ·
  • · Replies 19 ·
