Coil Moving through a Magnetic Field velocity
The discussion centers on calculating the force required to maintain the velocity of a rectangular coil moving through a magnetic field. The coil has a resistance of 2 ohms, dimensions of 3 cm by 8 cm, and moves at a constant velocity of 5 cm/s in a magnetic field of 1.6 T. At time t = 0.8 seconds, the force can be determined using the principles of electromagnetic induction, specifically Faraday's Law and the Lorentz force. Understanding these concepts is crucial for solving the problem effectively.
  • Faraday's Law of Electromagnetic Induction
  • Lorentz Force Equation
  • Basic Circuit Theory (Ohm's Law)
  • Understanding of Magnetic Fields and Forces
  • Study Faraday's Law and its application in induced electromotive force (EMF)
  • Learn about the Lorentz force and its implications in moving charges within magnetic fields
  • Explore circuit analysis techniques to calculate current and resistance in coils
  • Investigate the relationship between velocity, magnetic field strength, and induced force
Physics students, electrical engineers, and anyone interested in the principles of electromagnetism and their applications in real-world scenarios.
jdmarquardt
At t=0, a rectangular coil of resistance R = 2 ohms and dimensions w = 3 cm and L = 8 cm enters a region of constant magnetic field B = 1.6 T directed into the screen as shown. The length of the region containing the magnetic field is LB = 15 cm. The coil is observed to move at constant velocity v = 5 cm/s. What is the force required at time t = 0.8 sec to maintain this velocity?
image:
https://wug-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?cc/DuPage/phys2112/summer/homework/Ch-27-Induction/IE_B_field_from_movingcoil/pic2.gif
not actually sure where to start. any suggestions on where to start would be welcomed.
Thank you.
Hi jdmarquardt. Since you are asked to find a force, you should first try to understand conceptually why a force would be required to move the coil at constant speed.
