| New Reply |
The de Broglie wavelength of molecules |
Share Thread | Thread Tools |
| Jul27-12, 03:50 AM | #1 |
![]() 3. The attempt at a solution I first attempt part (a) since both parts are similar: (a) I need to know "v" in order to use the following equation to find the de Broglie wavelength: [itex]\lambda = \frac{h}{p} =\frac{h}{mv}[/itex] So I first found the kinetic energy of a N2 molecule: [itex]K=3(1.38065 \times 10^{-23})(300)/2 = 6.21292 \times 10^{-21} \ J[/itex] So I used the following relationship to work out v [itex]K=\frac{1}{2} mv^2 \implies v = \sqrt{\frac{2K}{m}} = \sqrt{\frac{2(6.213 \times 10^{-21})}{28(1.6605 \times 10^{-27})}}[/itex] [itex]\therefore \ v=516.96 \ m/s[/itex] [itex]\lambda = \frac{6.63 \times 10^{-34}}{(28(1.6605\times 10^{-27})\times 516.96)} = 2.7593 \times 10^{-11}[/itex] My answer seems wrong because this is 0.0275 nanometers (or 27.589 picometers) which is in the X-ray region of the spectrum! So what did I do wrong? ![]() Also the question says "compare this with the diameter (less than 1 nm) of the molecule", what does that mean? My value for λ is shorter than the diameter of the molecule which doesn't sound right. Any help is greatly appreciated. |
| Jul27-12, 04:28 AM | #2 |
What does the de Broglie wavelength tell you about the behaviour of a particle in a physics experiment?
| Jul27-12, 04:25 PM | #3 |
| Jul27-12, 04:43 PM | #4 |
Your working looks good to me, I think. Think about it this way - what would be the de Broglie wavelength of, say, a lead atom or an electron with the same kinetic energy as the sodium atom above? Doe that help?
| Jul28-12, 01:37 AM | #5 |
The de Broglie wavelength is not associated with an electromagnetic wave like an X-ray. Does that help?
So if it isn't an electromagnetic wave what use is it? What insight into the behaviour of large things and small things is it giving you? |
| Jul28-12, 06:38 AM | #6 |
| Jul28-12, 06:52 AM | #7 |
now try the ultra cool question (part b) |
| Jul28-12, 10:00 PM | #8 |
[itex]K=3(1.38065 \times 10^{-23})(450\times10^{-12}) /2 = 9.3194 \times 10^{-33} \ J[/itex] [itex]v= \sqrt{\frac{2(9.3194 \times 10^{-33})}{23(1.6605 \times 10^{-27})}} = 6.98595 \times 10^{-4} \ m/s[/itex] [itex]\lambda = \frac{6.63 \times 10^{-34}}{(23(1.6605 \times 10^{-27}))\times (6.9859 \times 10^{-4})} = 2.48497 \times 10^{-5} \ m[/itex] So the de Broglie wavelength is 24.85 μm. Is this correct as well? I'm not sure if it was valid to apply the equation K=1/2mv2 to work out the velocity of the particle, since the kinetic energy of the particles were already given by another formula K=3kBT/2. I'm not sure if that equation is appropriate for this situation of gas particles.
| Jul29-12, 02:04 AM | #9 |
temperature reduced by 12 orders of magnitude so the de Broglie wavelength increases by 6 orders of magnitude. ( I haven't checked your actual calculation )
yes I believe that both energy equations can still be applied even at such low temperatures , you are right to be cautious of what velocity means when the particle is no longer behaving like an independent lump but like a wave. I know basically nothing about Bose Einstein condensates which is what this ultra cool part b is leading towards. This picture is basically the limit of my knowledge http://cua.mit.edu/ketterle_group/in...20is%20BEC.gif All the particles start to behave like a single particle - its beautiful and strange. Gotta love physics. |
| New Reply |
| Thread Tools | |
Similar Threads for: The de Broglie wavelength of molecules
| [SOLVED] [Multiple Choice] ...wavelength of an object. de Broglie wavelength | Introductory Physics Homework | 11 | ||
| de broglie wavelength | Introductory Physics Homework | 8 | ||
| The de Broglie wavelength | Biology, Chemistry & Other Homework | 5 | ||
| de Broglie wavelength | Introductory Physics Homework | 2 | ||
| de Broglie Wavelength | Introductory Physics Homework | 3 | ||
