Finding the electric field of a uniformly charged cylinder using Gauss' law
The discussion focuses on calculating the electric field of a uniformly charged cylinder using Gauss' Law. The charge density is denoted as L/m, and the radius of the cylinder is a. The electric field at a distance r (where r > a) is derived using the formula E = Q/(Aε), where Q is the charge, A is the area of the cylindrical surface, and ε is the vacuum permittivity. The participants confirm that for a very long cylinder, the surface area of the sides is significantly greater than that of the top and bottom, making the flux through the ends negligible, thus validating the use of Gauss' Law in this scenario.
  • Understanding of Gauss' Law in electrostatics
  • Familiarity with electric field concepts and calculations
  • Knowledge of vacuum permittivity (ε)
  • Basic calculus for integrating electric fields
  • Study the application of Gauss' Law to infinitely long wires and planes of charge
  • Learn how to derive electric fields using integration techniques for non-uniform charge distributions
  • Explore the concept of electric flux and its implications in electrostatics
  • Investigate the effects of finite-length charged cylinders on electric field calculations
Students and educators in physics, particularly those studying electromagnetism, as well as engineers and physicists working with electric fields and charge distributions.
Miscing
A very long cylinder has charge density L/m and radius a. Find the electric field at a distance r, with r > a.
I construct a gaussian cylinder around it with radius r, and then from Gauss' law the field at any point on it's side surface is E= Q/Ae, where A is the area of the side of the cylinder, e = vacuum permittivity. So, Q = L*length, A = 2*pi*r. This gets me the right answer in the textbook (L/(2*pi*e)), but there's a sticking point in my approach - this assumes all of the flux is concentrated through the sides, whereas there should also be some through the top and bottom of the cylinder, right? The best explanation I can think of is that because the cylinder is "very long", SA of the sides >>> SA of the top and bottom and so flux through these is negligible. This reasoning is a bit too heuristic for me though and it would be great if someone can give a better/more quantitative explanation.
I think that's why they said a very long cylinder. Have you seen the Gauss law problems with the infinitely long wire of charge, and the infinitely large plates of charge? that's so you don't have to deal with the ends and edges as that would be very difficult using gauss.
If you have used the integrative technique to find the strength of an E-field at some point outside a line of charge of known length, L, then you know it can be a pain. And then how about a round plate of charge with known radius R, that's a bit of a pain and its only a bit of a pain if you want to know the efield strength at some point that lies right along the axis of the center of the plate. It would be an enormous pain if the point was not in line with the axis of the plate. Now combine that with the fact that you would have more charge contributing to the E.field of some cylinder of known L as well... a HUGE math pain. Better to just measure it.
Its Gauss, its supposed to be a short cut for objects with some sort of spherical symmetry usually.
Awesome, thanks. I did try to set up the integral first and it quickly turned into a cluster**** haha
  • · Replies 22 ·
  • · Replies 26 ·
