Discrete Mathematics : Proof : Question 1
The discussion revolves around a proof in discrete mathematics involving set operations and Venn diagrams. The original poster is tasked with determining the validity of the equation (A-B) ∪ C = (A∪C) - (A∩B) for subsets A, B, and C of a universal set U.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use Venn diagrams and specific set examples to explore the validity of the equation. Some participants question the correctness of the calculations and suggest revisiting the definitions of set operations. Others propose drawing new Venn diagrams and using different examples to clarify the situation.
Participants are actively engaging in the problem, providing feedback on calculations and suggesting alternative approaches. There is a recognition of the need for a counter-example, and some participants have successfully identified potential examples that illustrate the original statement's validity or lack thereof.
There are mentions of the challenges posed by empty fields in Venn diagrams and the importance of including values in all sections to accurately reflect set relationships. The discussion also highlights the need for clarity in understanding set differences and intersections.
Supierreious
Question 1 :
a) Use Venn diagrams to determine whether or not, for all subnets A,B and C of a universal set U, (A-B) ∪ C = (A∪C) - (A∩B)
b) If the statement appears to hold, give a proof, if not, give a counter example.
*there are no other variables given
*no other values are known
*this question relates to the proof
a) I have drawn the Venn diagrams, which does not reflect that they equate to each other, so they are not equal.
b) The counter example is the one I am struggling with, so i will explain how i did it, and basically just adapted an answer from my textbook :
Attempt to prove with counter example :
Let : A = {1;2}
Let : B = {2;3}
Let : C = {1;4}
Left hand : (A-B) ∪ C :
(A-B) = = {1;2} - {2;3} = {1;3}
(A-B) ∪ C = {1;3} ∪ C = {1;3} ∪ {1;4} = {1;3;4}
(A-B) ∪ C = {1;3;4}
Now to find out what the right hand side is :
(A∪C) - (A∩B) :
(A∪C) = {1;2}∪{1;4} = {1;2;4}
(A∩B) = {1;2}∩{2;3} = {2}
(A∪C) - (A∩B) = {1;4}
Thus :
(A-B) ∪ C ≠ (A∪C) - (A∩B)
Please let me know if this is right, or where i can improve, this is something new to me, and i still need to work on this a lot.
Your steps are not correct. A - B is the difference, so
A - B = {1,2} - {2,3} = {1}. You are removing elements in AnB from A.
So, what you have is not a counter example. Try again :)
Thanks,
(A-B) ∪ C = {1;3;4}
should be :
(A-B) = = {1;2} - {2;3} = {1}
(A-B) ∪ C = {1} ∪ C = {1} ∪ {1;4} = {1;4}
(A-B) ∪ C = {1;4}
So that means that they are in fact the same... (i did not see that from my Venn diagram).
I will quickly draw the venn diagrams again, is there a way i can show you the venn diagrams on this forum ?
Ok, i have managed to upload a Venn diagram on these 2.
Please let me know why my venn diagram does not reflect the calculation..
Ingenious! Your Venn diagrams are correct. If you find 3 sets which obey the original statement it can be still false. Find a counter-example. What about the sets in the attachment?
ehild
Yes - if A n B n C is not empty, the proposition is false.
hi Ehild,
Thank you for the feedback, yes i can see the difference, only if a place a value in every field :)
The example i used had 'empty fields' - which does not point out the difference.
So in the process of answering this one (Correct me if i am wrong) :
1. Draw the venn diagrams
2. Put a value in every section (piece) of the venn diagram
3. Then do the calculations - due to the fields of the venn diagram , when writing out the proof it will be clear that the two are not the same
Just writing out my proof, if you can confirm, i will really appreciate it :
A = {1;2;6;7}
B = {2;3;5;7}
C = {4;5;6;7}
(A-B) ∪ C = {1;2;6;7} - {2;3;5;7} ∪ C
= {1;6} ∪ C
= {1;6} ∪ {4;5;6;7}
= {1;4;5;6;7}
Right Hand : ∪ ∩
(A∪C) - (A∩ B)
(A∪C) : {1;2;6;7) ∪ {4;5;6;7} = {1;2;4;5;6;7}
(A∩B) : {1;2;6;7} ∩ {2;3;5;7} = {2;7}
(A∪C) - (A∩ B) = {1;4;5;6}
and Thus :
Nice, that works. A simpler example might have been:
A = B = C = {1}.
Who, Ehild,
thanks a lot for your assistance, appreciated!
